Author Topic: Don't Soak Your Mechanical Keyboard In Windex Overnight  (Read 5783 times)
Offline Alex
« on: Sun, 01 May 2011, 14:22:50 »
Windex of all things.. This is a good example why you shouldn't believe everything that's written on the internet.
According to the movie My Big Fat Greek Wedding, windex is good for almost everything. But i don't think he mentioned anything about cleaning keyboards.
Offline False_Dmitry_II
« Reply #1 on: Sun, 01 May 2011, 16:48:09 »
At this point, if it were me, I'd take it all apart then blast it with water, then blast it with distilled water, then let it dry and hope for the best.
Or buy a new board.
Offline slueth
« Reply #2 on: Sun, 01 May 2011, 17:08:15 »
Maybe if your keyboard was made of glass windex might work.
Offline The Solutor
« Reply #3 on: Sun, 01 May 2011, 17:10:49 »
I admit I had to use wikipedia to understand what the Windex is.
It's just Glassex :happy:
Offline ricercar
  • mostly abides
« Reply #4 on: Sun, 01 May 2011, 17:50:41 »
Windex will cause the metal traces to peel off from mylar keyboard sheeting. While this specific problem isn't going to affect the Cherry key switches on that guy's DAS, it'll utterly ruin any rubber dome/scissors/buckling spring keyboard on earth.
Not that I'm speaking from experience or anything. Who'd ever be so foolish to wipe Windex onto a laptop keyboard mylar membrane?
(Wow, 8.1 years at [H] and only 3 posts. Guess that shows how I feel about [H].)
« Last Edit: Sun, 01 May 2011, 17:57:08 by ricercar »
Offline Chobopants
« Reply #5 on: Sun, 01 May 2011, 21:00:55 »
Oh lord that's rough. What people that don't read GeekHack will do. :(
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline ricercar
  • mostly abides
« Reply #6 on: Sun, 01 May 2011, 21:38:46 »
Quote from: ripster;340052
I don't think wiping it with Windex is any big deal.
Neither did I. But a simple wipe with a damp (not soaked) cloth was enough to kill two keyboard membranes in my experience. The metal just lifted off the plastic before I could even get the sheets assembled again.
« Last Edit: Sun, 01 May 2011, 21:40:55 by ricercar »
Offline godofdeath
« Reply #7 on: Sun, 01 May 2011, 21:42:21 »
he's a moron for listening to it
Offline Tennobanzai
« Reply #8 on: Sun, 01 May 2011, 21:54:55 »
Poor guy. Hopefully he learned his lesson to not believe everything on the net...
Offline ricercar
  • mostly abides
« Reply #9 on: Sun, 01 May 2011, 22:14:09 »
Quote from: ripster;340090
What board?
Powerbook Duo 210/230 scissors switch keyboard. Never wanted to test my hypothesis on anything else.
Offline Brummell
« Reply #10 on: Mon, 02 May 2011, 00:23:47 »
I thought all the idiots who dump things in their keyboards posted at OCN.  That had to be a cross-post.
Unicomp Space Saver | Filco Majestouch Blue | IBM Model M | Filco Majestouch Brown | Realforce 86UB | Leopold Blue | HHKB Pro 2
Offline Oqsy
« Reply #11 on: Mon, 02 May 2011, 02:32:56 »
He did both. You forgot about the fruit cup. How could you forget the fruit cup?
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline The Solutor
« Reply #12 on: Mon, 02 May 2011, 13:34:00 »
Quote from: ripster;340077
ammonia is a no-no for plastic.
On what issue of Mikey mouse magazine you read it ?
Ammonia does nothing to most plastics, other than a bit of whitening to the older one.
Does nothing also to copper.
That said is still a dumb idea to dump a whole keyboard in the ammonia or in a solution ot it because it attack aluminum which often is used for the matrix, and for electrolytic capacitors) and can attack some type of glues used on PCBs and keyboard matrix.
Is not a good idea also to clean the monitor screen, (no matter if LCD or CRT), because some of the antireflective coatings can be altered or completely wiped away
Offline digitalleftovers
« Reply #13 on: Mon, 02 May 2011, 13:52:48 »
Quote from: ripster;340093
One guy posted benzene.  The Internet is full of trolls (even with Chemistry backgrounds).
Actually, they posted "Benzin!".  Their chemistry background should have told them that Benzin[e] (that doesn't exist because "benz-" is a colloquial root) would be cyclo-hexane.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline bpiphany
« Reply #14 on: Mon, 02 May 2011, 14:52:08 »
Quote from: digitalleftovers;340483
They might have meant "gasoline" then, it's Benzin in german or bensin in swedish for example. I think some 100% heptane is sold in sweden under the description bensin when it's meant to be used as a solvent.
« Reply #15 on: Mon, 02 May 2011, 15:09:26 »
that makes more sense.
Keyboards:
Offline The Solutor
« Reply #16 on: Mon, 02 May 2011, 15:15:29 »
Quote from: PrinsValium;340520
Benzina, also in Italian.
Still not a good idea to use it to clean plastics, although some kind of plastics are perfectly compatible with this kind of solvents (PP for example)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #17 on: Mon, 02 May 2011, 15:23:43 »
Quote from: ripster;340104
I don't even believe Wikipedia.  The USB entry claims Standard USB A/B connectors are to prevent ground loops.
Your interpretation seems to be off. By "electrical loop" they certainly meant a connection from one host port to another and other such obvious nonsense.
woody
  •  Guest
« Reply #18 on: Mon, 02 May 2011, 15:34:44 »
You can't loop host port back to host port. Kinda like male and female genitalia.
woody
  •  Guest
« Reply #19 on: Mon, 02 May 2011, 15:43:31 »
Damn, I expected some homo counter-examples.
EDIT: Not sure what you're asking, but since in USB there is strictly master/slave connection, the A/B is so you don't foolishly try to pair master/master or slave/slave. And with the OTG it's even more interesting.
« Reply #20 on: Mon, 02 May 2011, 17:45:33 »
If you get a USB extension cable, and plug it into itself, you have accomplished exactly nothing. Besides making it look like Ouroboros (I can't believe I spelled that right) anyway.
I always thought the B connectors were stupid. In the past it's just meant that i have to have more cords, wheras if they were all like usb extension cables, or even male-male (like HDMI) it would have been much less annoying.
« Reply #21 on: Mon, 02 May 2011, 20:02:53 »
Yeah I dunno. I can't think of a way to plug a device into itself, no matter the shape of the plugs. So I don't see any electrical effects.
I mean, if they wanted a continuous shield or a break in it before the other connecter, they can do that no matter what.
Offline The Solutor
« Reply #22 on: Mon, 02 May 2011, 20:09:46 »
Quote from: ripster;340634
Two male connectors IS kinda alternative but still electrically irrelevant.
Usb devices were intended to to be connected in a chain, like PC ---> Printer ---> Scanner or PC --->Keyboard ---> Mouse and so on.
Feature that was mostly unused. The chain, unlike Ethernet, must provide also the power line and having two different connectors was a way to made the connection dumb proof.
A connector is the one that provide current, the B one drains it
Thast's all.
