Author Topic: The RipOruster - Checking Out Switch Wear and Spring Composition  (Read 7234 times)
Offline Mr. Perfect
So about the switch wear part, are you going to reassemble the switches afterwards? Or is this simply a rust test?
Also, WTF happened to that IBM spring?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline audioave10
« Reply #1 on: Sat, 14 May 2011, 23:06:24 »
This seems like it might just turn out as a useful test. Those springs "could" rust, but I might not be alive when it happens.
The first thing I thought, was that you would decide with the test if water or Windex was useful or not. Do you hope to eventually decide that too?
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline BababooeyHTJ
« Reply #2 on: Sat, 21 May 2011, 13:06:58 »
Should be an interesting experiment. I'll have to keep an eye on this thread.
Offline Mr. Perfect
« Reply #3 on: Sat, 21 May 2011, 15:45:54 »
Just as a point of reference, what are the staples and nails? Galvanized steel? They haven't done anything either. Do you have an uncoated steel item you can use as a control?
« Reply #4 on: Sat, 21 May 2011, 20:28:05 »
What are the leaves in the cherry switches? I had thought they were copper but if they are attracted to magnets that can't be the case.
« Last Edit: Sat, 21 May 2011, 22:23:07 by BababooeyHTJ »
Offline Mr. Perfect
« Reply #5 on: Sat, 21 May 2011, 21:55:28 »
If it's sticking to a magnet, then it's got iron in it. Maybe a copper plated steel?
Offline N8N
« Reply #6 on: Sun, 31 July 2011, 11:24:13 »
I thought that the Cherry ad copy implied that the MX series switches had gold plated contacts.  At least that's what I ASSumed that "MX gold crosspoint contacts" meant gold plating on the working bits.  Now what "crosspoint" means I have no idea.
Staring into the remains of this poor MX8100 that I just savaged for its caps, stems, and springs, the little contacty bits certainly look as though they may be gold plated.  Anyone have some HCl, HNO3, and a microscope that I could borrow for a few?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #7 on: Fri, 07 October 2011, 13:39:00 »
You shouldn't use metal (nails) to mount the stuff on the wood :3
A Ghost From The Past
« Reply #8 on: Fri, 07 October 2011, 20:33:16 »
I'm a bit surprised my the lack of any real corrosion after six months.
Offline SidusNare
  • Do, or do not; there is no try.
« Reply #9 on: Fri, 23 March 2012, 22:47:08 »
have you tried an oxidizer or accelerant on new springs? would give quicker and more extreme results.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
