Author Topic: WTF is wrong with my monitor?!  (Read 3656 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Fri, 03 August 2012, 20:56:15 »
So, about a month ago I noticed I had a pixel that was stuck, and would change colors depending on the background.
It has been growing pixel-by-pixel everyday, and now looks like this! The weird thing is, you can see under the blotch. It's faint but you can.
And just a few days ago, I noticed one forming at the top of my monitor too.
Offline alaricljs
  • I be WOT'ing all day...
Re: WTF is wrong with my monitor?!
« Reply #1 on: Fri, 03 August 2012, 21:05:31 »
That is quite unique.  Mine has a vertical line from top to bottom until the monitor warms up, it has occasionally been 2 lines ~4 pixels apart.  I haven't figured out which color(s) are off because that requires effort.
What model monitor do you have?  I can't imagine a failure mode that effects individual pixels like that.
Filco w/ Imsto thick PBT
  • I <3 60%
« Reply #2 on: Fri, 03 August 2012, 21:22:37 »
I have a HP w2207h
I think it's a little over 4 years old. It was damn expensive at the time too.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Sat, 04 August 2012, 19:22:02 »
You should get a CRT monitor!
Offline Christown
  • MX Blue >
« Reply #4 on: Sun, 05 August 2012, 05:44:45 »
Looks like it's leaking.
Offline godly_music
« Reply #5 on: Sun, 05 August 2012, 06:07:18 »
Looks like your monitor is creating a rift to another dimension.
There is a dead pixel remover written in Java floating around the net. If that doesn't help, you can try rubbing the spot gently. If that doesn't help either, then I guess the're permanently gone.
« Reply #6 on: Fri, 10 August 2012, 03:24:30 »
My guess is that something got inside the display and is slowly damaging the transistors on it's slow return to gravity. I hope that's not it, though. New monitors are expensive!
