Author Topic: Cherry G81-1800  (Read 4112 times)
Offline rao2100
Cherry G81-1800
« on: Sat, 04 August 2012, 07:39:15 »
| KMAC LE Vintage Blues | LZ-S Ergo Clears | Filco TKL MJ2 Ninja Reds | CM QFR - Blues | IBM Model M SSK 1991 |
Offline Wildcard
  • When caffeine isn't enough
Re: Cherry G81-1800
« Reply #1 on: Sat, 04 August 2012, 08:31:23 »
This board has Cherry 'MY' swiches and lasered tops. The keycaps are MX compatable, but this wouldn't have a full set.
You'll see these pop up quite a bit on ebay.
Keep looking for a G80 which will have MX switches of some variant.
Offline rao2100
Re: Cherry G81-1800
« Reply #2 on: Sat, 04 August 2012, 08:42:46 »
Thanks for the clarification RiffRaff
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Cherry G81-1800
« Reply #3 on: Sat, 04 August 2012, 09:17:58 »
so if they are "my switches" then which mx switches would you say they are closet to?
and you do say that they ARE mx keycap compatable?
thanks!
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline sth
  • 2 girls 1 cuprubber
Re: Cherry G81-1800
« Reply #4 on: Sat, 04 August 2012, 09:23:12 »
Closest to blacks in a really unpleasant way. A few people like them but most do not. Some people remove the springs from the switches to create a very light (35g) linear switch.
The keycaps are MX compatible but these aren't really anything that special aside from probably being somewhat thicker (though I could be wrong as I am not too familiar with too many USB MY boards).
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Cherry G81-1800
« Reply #5 on: Sat, 04 August 2012, 10:02:42 »
Nothing special at all, only the keys that are nonstabilized are useable and the new Cherry pbt keys are thin as hell. In short, not worth buying these at all unless you want a nice new white casebody for a G80-18**.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Cherry G81-1800
« Reply #6 on: Sat, 04 August 2012, 10:44:17 »
so what i'm seeing then is minus the caps and switches pretty much only the case is good for salvaging to use maybe somewhere down the road?
you guys are great........
Offline inlikeflynn
  • file not found
Re: Cherry G81-1800
« Reply #7 on: Sat, 04 August 2012, 10:50:18 »
yea just the case is good from these. I'm grabbing one just for the case for a special project
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Cherry G81-1800
« Reply #8 on: Sat, 04 August 2012, 10:53:46 »
thanks............saved me a couple bux.
wanting to get a cherry board at some point, but because there are so many can't keep straight :-\
Offline Djuzuh
Re: Cherry G81-1800
« Reply #9 on: Sat, 04 August 2012, 10:57:48 »
Check out Deskthority's wiki.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Cherry G81-1800
« Reply #10 on: Sat, 04 August 2012, 11:19:25 »
big help.............thanks ;D
so then the g80-1800's are the bomb then and the g81-1800's are just so-so
feeling smarter already
Offline inlikeflynn
  • file not found
Re: Cherry G81-1800
« Reply #11 on: Sat, 04 August 2012, 18:02:46 »
yea the DT cherry model number wiki is the best reference on these at the moment
http://deskthority.net/wiki/Cherry_Product_Numbers
Just because it is G81 doesn't mean its bad though, it could still have double shots if it has the "H" in the model name.
and you know I think G80-1800's are the bomb  ;D
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Re: Cherry G81-1800
« Reply #12 on: Sat, 04 August 2012, 22:06:36 »
The most awesome are the G80-1813HFU, G80-1838HPU and G80-1863HUMUS-2 WNV edition. I would say those are the 3 that are most worth looking for. The original Raptor Gaming K1 is also pretty good one if you can find it.
« Last Edit: Sat, 04 August 2012, 22:09:19 by lysol »
