Author Topic: [IC/brainstorming] phantom kits run 2  (Read 57182 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: [IC/brainstorming] phantom kits run 2
« Reply #150 on: Tue, 04 September 2012, 14:42:14 »
+/-.004" now? I was told +/-.002"
anyways tighter is better wink wink
Now you are mixing tolerances.  .002 is the hole sizing tolerance.  .004 is the plate thickness tolerance.
The local place i tried going to can only do a tolerance of +/- 0.005 which i assume isnt good enough is it?
got word back from bpiphany:
"If you look at the datasheet for the switches 0.005" is close to good enough on most numbers. I had plates water cut with at least a larger radius. I don't know how good their overall accuracy was. My corners were a bit too round, but that was no problem either. I can't make any promises but I think you would be doing fine with that tolerances. The most crucial parts turned out to be the costar stabilizers. You may need to do a tad of filing to get them to seat properly.
http://www.cherrycorp.com/english/switches/key/mx.htm"
« Reply #151 on: Wed, 12 September 2012, 16:35:54 »
Got my custom plates from the laser cutter today and their really nice and fit the switches perfectly.
Offline __red__
« Reply #152 on: Thu, 13 September 2012, 13:28:04 »
Care to share the company name so I can send the some designs for quotes?
« Reply #153 on: Thu, 13 September 2012, 16:40:23 »
o sure i didnt even think about that
American-3 Fab, Inc.
1850 Cofrin Dr.
Green Bay, WI 54302
Ph: 920-569-1880
Fax: 920-569-1885
Offline phetto
  • HHKB JP
« Reply #154 on: Tue, 02 October 2012, 14:01:08 »
Interested.
« Reply #155 on: Sun, 04 November 2012, 01:45:50 »
Are there going to be chamge to the pcb in round 2 so many designs have been heading towards smd.
Offline leesofi
  • super lurking
« Reply #156 on: Sun, 04 November 2012, 05:35:09 »
i`ll join
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #157 on: Sun, 04 November 2012, 10:12:11 »
yes, i think bpiphany's going to work on a revised phantom pcb after he finished up the filco replacement controller stuff
Offline bpiphany
« Reply #158 on: Sun, 04 November 2012, 10:56:35 »
Yes, this is a priority design project =) The controller business may calm down a bit soon, I hope... I've done my soldering practice now =P
Offline esoomenona
  • Gnillort?
« Reply #159 on: Sun, 04 November 2012, 11:20:48 »
« Last Edit: Mon, 21 September 2015, 14:57:53 by esoomenona »
« Reply #160 on: Sun, 04 November 2012, 14:06:06 »
yes thanks for all the practice, cant wait to get mine!
