Author Topic: [IC/brainstorming] phantom kits run 2  (Read 57181 times)
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: [IC/brainstorming] phantom kits run 2
« Reply #100 on: Sat, 25 August 2012, 11:10:31 »
Neat, there's 2 different 7bit layour images here:  http://deskthority.net/marketplace-f11/phantom-custom-keyboard-group-buy-closed-t1411.html   one is iso left shift the other isn't.
According to the plate images, 7bit's is wonky/reverse iso
yes that is the case and i though it was wonky as well and am happy with iso style. i am not however really getting used to having 4 spacebars. so if its possible to make the plate have just one big standard one with a plate modification i might go through the trouble of that. Im thinking standard ansi 1.25 mods first row.
« Last Edit: Sat, 25 August 2012, 11:14:33 by TheProfosist »
Offline swe3tdave
« Reply #101 on: Sun, 26 August 2012, 06:11:07 »
I don't know much about copyright technicalities =) But I think that stuff you make you kind of automatically achieve some sort of copyright over. The phantom plates are free for anyone to use though, and they are included in my attachment four posts up =D
It almost sounds like you never heard of Open source?  :eek:  :p
Sure i'm in for the group buy if there is another one, i might even buy more than one, but i always like to have the option to have one made with a few modification of my own if the need comes... :)
Offline bpiphany
« Reply #102 on: Sun, 26 August 2012, 07:28:11 »
Well as I said I don't really know much about it. But I think I am still technically the copyright holder. I just say that anyone is allowed to do whatever they want with it. I don't have the time or interest in reading up on different open source licenses...
Offline swe3tdave
« Reply #103 on: Sun, 26 August 2012, 08:04:12 »
yeah thats fine, anyway i was just fussing a little about it...  :-X But yes, whatever you do, you're still the copyright holder.
« Last Edit: Sun, 26 August 2012, 12:22:27 by swe3tdave »
Offline swe3tdave
« Reply #104 on: Sun, 26 August 2012, 13:33:23 »
This is the layout i made for a steampunk keyboard i want to build. I was looking to do something like this: http://www.rampkins.com/buccaneer_steampunk_kb_buildlog.html
The Fn key i added is for programmable shortcut and adding things like play, stop, etc... Will it be possible to do this with the phantom rev 2?
« Reply #105 on: Sun, 26 August 2012, 17:05:21 »
layers are already working on the original phantom and media keys are probably soon to come as they are available on other keyboards that use the teensy.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #106 on: Mon, 27 August 2012, 07:32:28 »
The lazer guy got back to me $25.00 for whatever plate jdcarpe sent me first and he would be using .063” 5052-h32 aluminum.
I'll be asking him about finding .060" material and if he really can maintain +/- .002" since he doesn't say it outright. Any other questions?
I can't find the other thread talking about plates, UH60 or something like that.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #107 on: Mon, 27 August 2012, 08:21:02 »
Typically you can only get steel in .060  (That's 16 ga).
Filco w/ Imsto thick PBT
Offline bpiphany
« Reply #108 on: Mon, 27 August 2012, 08:21:25 »
Would anyone be interested in a "Teensy" compatible (ATmega32u4) daughter controller board for their Filco tenkeyless?
2893-0
« Reply #109 on: Mon, 27 August 2012, 08:22:28 »
I would be interested in 3 or 4 of them.
« Reply #110 on: Mon, 27 August 2012, 08:25:05 »
bpiphany, would you be willing to help us make a Phantom Mini (60%) board? My GH60 keyboard thread basically turned into people wanting the Phantom PCB and plates, but cut down to 60% size. Controller would likely be ATMega32U4 based integrated onto the PCB (SMD) and mouting holes to fit a Poker case need to be included.
If so, maybe we could run both the Phantom Round 2 GB and the 60% GB at the same time.
« Last Edit: Mon, 27 August 2012, 08:28:18 by jdcarpe »
Offline alaricljs
« Reply #111 on: Mon, 27 August 2012, 08:28:01 »
I'd get 2
Offline alaricljs
« Reply #112 on: Mon, 27 August 2012, 08:28:43 »
No more combining GBs.  It wreaks havok all around.
ed: ate breakfast, came back fixed typo :)
« Last Edit: Mon, 27 August 2012, 08:57:46 by alaricljs »
« Reply #113 on: Mon, 27 August 2012, 08:30:01 »
Haha, okay.
Offline bpiphany
« Reply #114 on: Mon, 27 August 2012, 08:30:12 »
That shouldn't be too hard to do either.  The nice thing with a tenkeyless (and fullsize) is the space between the number and function row. There it is simple to squeeze in whatever components needed. It is far from impossible to manage it anyway, only a little bit trickier in placing everything smarter =)
Edit: Ok, perhaps I should open a new thread on the replacement controller at least...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #115 on: Mon, 27 August 2012, 08:35:52 »
I'd be in for a TKL or a 60%
« Reply #116 on: Mon, 27 August 2012, 14:44:29 »
same im just having fun building these things!!!
Offline __red__
« Reply #117 on: Mon, 27 August 2012, 14:52:37 »
That's a great price.  Contact details or is this favourville?
Offline damorgue
    • Personal portfolio
« Reply #118 on: Mon, 27 August 2012, 16:12:46 »
What number of plates was that quote for?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #119 on: Mon, 27 August 2012, 16:19:42 »
One
Any question you want me to ask him tell me now. (I'm sure we'll get price breaks for ordering more, I was going to ask :D )
« Reply #120 on: Mon, 27 August 2012, 16:22:44 »
That is a great price. Do you know of somewhere local to you to have it anodized?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #121 on: Mon, 27 August 2012, 16:27:13 »
Yes but there is a $500 setup charge and they have to weld on hooks. But maybe the hooks just for the 120 lbs, 25' aluminum bars we send them. I'm not 100% sure on the hooks or the pricing since most of that is done by a purchasing guy where I work, I just engineer it :D
Offline jcrouse
« Reply #122 on: Mon, 27 August 2012, 16:30:16 »
If you're getting quotes for plates, send an RFQ to www.ohiolaser.com. For the ANSI phantom plate (87 TKL) they quoted me the following prices out of 1/16" cold rolled steel. I realize you may change material but give them a try.
Qty 1: $119.66 each
Qty 50: $10.22 each
Qty 100: $9.11 each
*** disclaimer *** I have no affiliation what-so-ever with these people. I just found them with Google.
Offline damorgue
« Reply #123 on: Mon, 27 August 2012, 16:35:22 »
That one is cheaper than my source for large number of stainless steel plates but more expensive than mine in smaller numbers. Mine were on the other hand 1.5mm thick and will probably not have to be sanded down a bit in thickness for a good fit. I think the perfect thickness was 1.5mm, right?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #124 on: Mon, 27 August 2012, 16:42:45 »
.060" because metric sucks
(jk I like metric more)
Offline jcrouse
« Reply #125 on: Mon, 27 August 2012, 16:46:00 »
FYI ...
1/16 = .0625
16ga = .0598
There are a few ways to measure "sheet metal"
« Reply #126 on: Mon, 27 August 2012, 16:46:08 »
I might be getting some custom ones at a local place but back when i got the quote it was 62$ a plate for 4 plates. I will just be ordering 2 now as that is all i need. Also I will probably be selling 2 of my 7bit modified plates if anyone is interested.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #127 on: Mon, 27 August 2012, 18:11:53 »
That's a lot compared to my place.
Offline damorgue
« Reply #128 on: Mon, 27 August 2012, 18:27:17 »
I though yours were aluminium?
We need to make a list of places where we ask quotes, and also mention which material and what size was aksed about (60%, TKL or Full) as well as the number of plates.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #129 on: Mon, 27 August 2012, 18:41:27 »
Yup,  5052-h32 1/16" aluminum in what looked like a TKL layout (I just wanted a quote, if you want more just ask since I'll be sending him another email within a few days)
Offline alaricljs
« Reply #130 on: Mon, 27 August 2012, 18:45:40 »
Just a reminder... .060 +/- .004 is extremely important for Costar stabs and plate mount Cherry stabs to lock onto the plate.  It's only slightly less important for plate mount switches, but really should be adhered to.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #131 on: Mon, 27 August 2012, 18:49:12 »
+/-.004" now? I was told +/-.002"
anyways tighter is better wink wink
Offline damorgue
« Reply #132 on: Mon, 27 August 2012, 18:57:08 »
Some have asked for stainless steel, which is why there is quite a large variation in price.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #133 on: Mon, 27 August 2012, 19:01:37 »
I think I could get stainless steel, but I'm not sure if the laser he has is powerful enough. Is this something I should ask?
Qty 1: $119.66 each
Qty 50: $10.22 each
Qty 100: $9.11 each
He got a quote for cold rolled steel, not stainless.
« Reply #134 on: Mon, 27 August 2012, 19:15:32 »
My quote was for stainless. and was probably so expensive because i only wanted a few.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #135 on: Mon, 27 August 2012, 19:17:08 »
OHHHH ok, now I see why they were a bit high.
did you get .060" or 1/16" (since it's steel it should be .060")?
Offline damorgue
« Reply #136 on: Mon, 27 August 2012, 19:18:04 »
Ah, I read stainless somehow. Sure, ask away. I have a quote for $40 per TKL plate in low numbers in 1.5mm cold rolled stainless steel with rounded edges (so that they won't cut hands) and 2B finish.
« Reply #137 on: Mon, 27 August 2012, 19:18:45 »
it was originally for 1/16 but i asked for another quote for just 2 plates using 0.060
Offline alaricljs
« Reply #138 on: Mon, 27 August 2012, 22:12:42 »
Now you are mixing tolerances.  .002 is the hole sizing tolerance.  .004 is the plate thickness tolerance.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #139 on: Mon, 27 August 2012, 22:18:49 »
Re-read, 100% clear now
So 1/16" plate would work right since it's within the +/- .004 of the plate thickness?
« Last Edit: Mon, 27 August 2012, 22:21:29 by The_Beast »
Offline swe3tdave
« Reply #140 on: Tue, 28 August 2012, 20:00:57 »
hey guys, i'm kinda new here and you might know this but i've found a place where you can buy leftover stock for cheaper than the market prices.
http://www.verical.com
the prices can vary a lot from day to day, but i've seen cherry mx switch for as low as 0.22$ a piece. Right now there is a deal for 396 pieces at 0.36$ and another for anything between 101 and 15904 at 0.50$ Sometime there is a link where you can make an offer.
Anyway looked like it was worth mentioning..  ;D
Offline WhiteFireDragon
    • youtube
« Reply #141 on: Tue, 28 August 2012, 22:04:34 »
Interested in a poker/PURE size as well.
Offline damorgue
« Reply #142 on: Tue, 28 August 2012, 22:24:57 »
Seems pretty great. Why the odd sized batches at random times? Are they really new or refurbished stock, perhaps left overs or desoldered?
Offline alaricljs
« Reply #143 on: Tue, 28 August 2012, 22:40:41 »
Not necessarily because the plate you're looking at is not a perffect 1/16", it's 1/16" +/- some tolerance that may push it outside the envelope you are looking for.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #144 on: Tue, 28 August 2012, 22:41:40 »
^^^ Gottcha, I didn't think of that
"Ben, to answer your questions there are price breaks for larger quantities. We should be able to hold that tolerance and we can do stainless steel but the price will be a lot more."
My laser guy got back to me on the tolerance question, price breaks and different materials
« Last Edit: Tue, 28 August 2012, 22:44:32 by The_Beast »
Offline damorgue
« Reply #145 on: Tue, 28 August 2012, 22:51:38 »
Apparently aluminium is less prone to get sharp edges because it is rather soft and melts more easily. Stainless steel can get sharp when cut which is why they send the parts through a brushing machine to both get the surface right and to deburr.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #146 on: Tue, 28 August 2012, 23:03:37 »
Even on a laser cutting? Do lasers give clean edges, because I've heard they are a bit messy (I haven't seen much lasered aluminum since I work in the office and only go into the plant if there is a problem)
Offline swe3tdave
« Reply #147 on: Tue, 28 August 2012, 23:07:56 »
Basically verical.com is like overstock.com but for electronic components. All the quantity and prices are from live stocks that can be shipped quickly. Everything is still under manufacturer warranty. Anyway, there is an introduction video on the front page if you want to know more...
Offline __red__
« Reply #148 on: Wed, 29 August 2012, 06:44:19 »
Holy crap, that's awesome.  Thanks for posting!
Sent from my VS920 4G using Tapatalk 2
« Reply #149 on: Tue, 04 September 2012, 12:19:04 »
The local place i tried going to can only do a tolerance of +/- 0.005 which i assume isnt good enough is it?
