Author Topic: Num Lock LED brightness in QPAD MK85; suitable resistor value to dim it.  (Read 1817 times)
Offline Ian S
Hi,
I did a search within Geekhack for QPAD and nothing was found, so am starting this new thread.
I have a QPAD MK85 (with Cherry reds) and the Num Lock is very bright.
I had a look in there and saw and measured a 470 Ω surface mount resistor in series with the LED.
Questions:
• Can you suggest a suitable value to cut that brightness right down?
• Will cutting the current taken out from (what I presume is) the +5 Volt supply at that point have any adverse effect on anything in there.
Thanks.
« Last Edit: Wed, 08 August 2012, 14:36:38 by Ian S »
QPAD MK85 MX-red currently wearing beige vintage Cherry double shots.  Logitech K750.  Cherry G80 1000 with Blacks / Grey (circa 1990) that I've had since about 1994.
Sold: Realforce 88UB 45g; QPAD MK80 MX-Blue.
