Author Topic: Looking for ML keycaps  (Read 4760 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Tue, 07 August 2012, 12:05:54 »
I got a g84 for a friend, and he really wants some colored keycaps. I've seen different colored ones out there, im just not sure where to get them. any suggestions?
Offline MMB
Re: Looking for ML keycaps
« Reply #1 on: Tue, 07 August 2012, 12:10:34 »
I have never seen colored keycaps for a G84, but I got some replacement ones here http://www.ebay.com/itm/New-Cherry-83-Key-Keyboard-Assembly-Replacement-G84-4137-Dark-Grey-4100-Series-/221010685841?pt=PCA_Mice_Trackballs&hash=item3375436f91#ht_500wt_1181
I suppose you could just dye some white ones any color you want, and i believe they are PBT.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Tue, 07 August 2012, 13:26:06 »
SP does them according to thier products page.
Offline MMB
« Reply #3 on: Tue, 07 August 2012, 13:27:56 »
Not sure you would get enough interest to create a GB through SP, though. Unless they have ready stock available.
  • I <3 60%
« Reply #4 on: Tue, 07 August 2012, 15:41:03 »
The ones I saw must have been died. they were blue with blank black mods.
« Reply #5 on: Thu, 09 August 2012, 09:46:55 »
I'm pretty sure not all are PBT. Mine are Dyesub, but others are lasered or pad printed. I suspect the black ones are POM or ABS. The Beige should be PBT (like I have) or ABS.
Does anyone have a lasered or pad-print G84 they would like to look under the keycaps?
Offline poxeclipse
  • Hit me with music ... yes, me friend
« Reply #6 on: Fri, 10 August 2012, 22:45:52 »
Try this:
http://www.smartkeyboardsolutions.com/cherry-mx-switches.htm
I think they are an 'all women' shop in Arizona.
« Last Edit: Fri, 10 August 2012, 22:48:37 by poxeclipse »
« Reply #7 on: Sat, 11 August 2012, 01:37:49 »
Try this:
Looks to me like they just get and re-sell SP keycaps.
