Author Topic: KOREAN SWITCH STICKER GROUP BUY! (RECEIVED)  (Read 171413 times)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: KOREAN SWITCH STICKER GROUP BUY! (ENDS FRIDAY 8/17)
« Reply #100 on: Thu, 09 August 2012, 22:30:51 »
with a crowbar
NOT COOL, not cool at all... :)
-Enzo Ferrari
Offline MMB
« Reply #102 on: Thu, 09 August 2012, 22:46:14 »
well at least it's not comic sans
Offline MMB
« Reply #103 on: Thu, 09 August 2012, 22:46:53 »
:D
Offline WhiteFireDragon
    • youtube
« Reply #104 on: Fri, 10 August 2012, 05:39:06 »
Do these dampen noise in the same way O-rings do? And in what ways do they stabilize the switches more?
Looking to get this for my phantom build, but I'm not sure if I'm willing to wait that long, as I already have all my phantom parts.
Offline Ian S
« Reply #105 on: Fri, 10 August 2012, 05:53:25 »
No.
O rings stop the switch bottoming.
These stop the top half of the switch from moving around sideways and up and down a bit on the bottom half, and making some rattling sound.  They also therefore reduce the key cap sideways movement a bit.
I've never used them but did read the threads.
Have a look at my post at the top of page three of this thread.  Click the link, download and listen to the mp3.  It convinced me. :)
I just have to determine how many stickers I want and complete the form.  :)
There are people here who have first hand experience of these and I'd have left it to them to post but I'm posting this reply as I want to place an add and I guess I need more posts.
« Last Edit: Fri, 10 August 2012, 05:58:27 by Ian S »
QPAD MK85 MX-red currently wearing beige vintage Cherry double shots.  Logitech K750.  Cherry G80 1000 with Blacks / Grey (circa 1990) that I've had since about 1994.
Sold: Realforce 88UB 45g; QPAD MK80 MX-Blue.
« Reply #106 on: Fri, 10 August 2012, 16:31:49 »
No.
i wish more people were like you.
ask questions, once they got a slight explanation of what you wanted to know.. you go and research it more yourself.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #107 on: Fri, 10 August 2012, 16:45:37 »
Alls I knows is...stickers + slider lube + oiled 62g spring + clear stem = the perfect switch.  If stickers are part of the equation, stickers it must be period.
Offline limmy
« Reply #108 on: Sat, 11 August 2012, 00:56:39 »
You should also try lubed + stickered + spring modded vintage blacks.(have you?) They are favorite choice for many Korean keyboard enthusiasts.
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #109 on: Sat, 11 August 2012, 01:14:24 »
What are spring modded vintage blacks? o-o
Offline kaiserreich
  • HHKB Elite
« Reply #110 on: Sat, 11 August 2012, 01:17:09 »
I have 62G + clear stem + slider lube.
Turn out to be one of my favorite switches
« Reply #111 on: Sat, 11 August 2012, 02:21:34 »
i thought the whole big deal of vintage switches were the springs.
spring modded vintage blacks just sound like regular blacks with different springs.
unless im missing something?
Offline limmy
« Reply #112 on: Sat, 11 August 2012, 02:33:14 »
Well.. vintage black in KBDMania are more about quality of sliders and switch housing. Not many people I know use vintage black springs. They all switch out the springs.
Modern blacks and vintage blacks are pretty different. The latter is known to be significantly smoother than the former.
Maybe it is pretty different here in GH. (care more about springs)
Offline sth
  • 2 girls 1 cuprubber
« Reply #113 on: Sat, 11 August 2012, 02:39:16 »
is that due to a manufacturing difference or just because vintage blacks are old and worn out?
« Reply #114 on: Sat, 11 August 2012, 02:42:36 »
the more you know!
thanks limmy :)
Offline limmy
« Reply #115 on: Sat, 11 August 2012, 02:49:19 »
NIB vintage ones are used and preferred, so I would say it is manufacturing difference. Some people break NIB G80-2551 just to get vintage Cherry black switches.
Offline kaiserreich
  • HHKB Elite
« Reply #116 on: Sat, 11 August 2012, 02:59:55 »
Which spring do you use together with the vintage blacks?
I have a NIB WYSE, and they are very smooth.
« Reply #117 on: Sat, 11 August 2012, 03:18:50 »
My 356mini has 62g iirc and vintage blacks
Offline DanGWanG
  • Higher Standards
Re: Re: KOREAN SWITCH STICKER GROUP BUY! (ENDS FRIDAY 8/17)
« Reply #118 on: Sat, 11 August 2012, 10:09:08 »
Haven't tried it yet but I definitely planned on it :)
Offline jcrouse
« Reply #119 on: Sat, 11 August 2012, 10:34:58 »
Are these sticky on both sides, like double sided tape or just on one side in which they really only use their thickness to "tighten things up", from a mechanical perspective not from adherance.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #120 on: Sat, 11 August 2012, 10:43:13 »
I know they are definitely not sticky on top, I didn't even check the underside of any since they were already assembled and I was just stuffing diodes.
Filco w/ Imsto thick PBT
Offline reaper
« Reply #121 on: Sat, 11 August 2012, 10:43:42 »
Just one side... just like a normal sticker and not double sided one.
Din Eli
Offline Djuzuh
« Reply #122 on: Sat, 11 August 2012, 10:44:41 »
Oh, I thought they were double sided xD.
Thanks for the clarification !
Offline jcrouse
« Reply #123 on: Sat, 11 August 2012, 18:37:35 »
Well, I thought so also. Now I need to ask, "why not". Other than they would be more expensive but wouldn't they do a better job?
I apologize if I already mentioned this idea, but since we are on the topic .... When I watch the video of the person wiggling the keycap that shows the switch wobbling around, hence the need for these stickers, although I now just consider them spacers, I also look at the movement between the switch and the mounting plate. I also think it would be a great idea to have a sticker, both sides with adhesive, between the bottom half of the switch and the mounting plate. There was quite a bit of slop there. And as I follow the phantom thread I know there is some switch wobble in the omunting plate due to the way the coreners in the plate were relieved so the switch could be disassembled which still soldered and mounted. The clearance that was cut into the corners significantly reduced the surface are on two of the sides of the switch. This was even mentioned in the thread about the wobble. The stickers we are buying here look fairly thick and I guess that works, as long as the switch halves snap together but I don't believe the new ones I speak of for between the plate and bottom half of the switch need to be that think since the tabs still need to clip the switch to the plate. So two questions ...
Is it a good idea to have the stickers above be double sides adhesive?
Would a double sided sticker between the switch and plate help reduce the wobble even more?
I think I have mentioned this to two or three people via PM and never got much feedback so I'll throw it out here in the wild for critique.
Thanks,
John
Offline alaricljs
« Reply #124 on: Sat, 11 August 2012, 20:26:49 »
I have a phantom plate in front of me with switches inserted and they don't budge at all.  The top housing can still move, but if you grasp the bottom housing and try to move it, good luck and don't stab yourself with the leads.  Even the switches w/ stabilizer holes are rock solid.
Offline limmy
« Reply #125 on: Sat, 11 August 2012, 21:49:48 »
doublesided tapes may work better but it would be harder to handle. Many people have hard time handling this single sided sticker for the first time(due to its shape; it is pretty thin) and it certainly requires some skill and practice to use this properly. I don't think many people would appreciate added difficulty.
First thing would be to establish that there is enough merit for using double-sided tape, if it performs just as good as single sided sticker we don't need to bother. Finding adequate factory would be the next step.
My gut feeling is that single-sided sticker is going to be just as good as double-sided one. The sticker is fairly thick resulting tight fitting and leaving little room for the adhesive to play a role. However, we would never know before we try them out though.
Why don't you make proto types using double-sided tapes with varying thickness and see if it performs well?
Offline harrison
« Reply #126 on: Sat, 11 August 2012, 23:16:45 »
I've posted a second order with comment to remove my first due to a change of shipping addresses.
Looking forward to the stickers :)
As for double sided tape... that would work assuming you can cut them accurately, and aren't using them on a PHANTOM where you can separate the switch housings post-installation and assembly.
[work]ducky tiger dk-9008G2, cherry mx brown|logitech performance mx
[home]corsair k70 LUX RGB, cherry mx brown|logitech G700s
Offline MarkPharaoh
« Reply #127 on: Sat, 11 August 2012, 23:19:02 »
Got my order in for two, can't wait to see how they do for my blue switches.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #128 on: Sun, 12 August 2012, 01:26:36 »
Double sided stickers would mean that opening the switch later would ruin the sticker.
Offline limmy
« Reply #129 on: Sun, 12 August 2012, 01:33:44 »
Hadn't thought of that. Good thinking! Double sided sticker would make disassembling nightmare as well.
Offline Ian S
« Reply #130 on: Sun, 12 August 2012, 07:12:42 »
May also ruin the switch as you'd have to pry and cut away until the top half became free.
Re: KOREAN SWITCH STICKER GROUP BUY! (ENDS TUESDAY 8/14)
« Reply #131 on: Mon, 13 August 2012, 00:02:33 »
change of date. will be closing it on tuesday now. need to get this done already. orders have started to slow down anyway.
Offline DanGWanG
  • Higher Standards
« Reply #132 on: Mon, 13 August 2012, 00:05:09 »
Excellent news!
Offline mickd
« Reply #133 on: Mon, 13 August 2012, 00:12:01 »
Would we be required to de-solder the switches to use these on a Filco MJ1 or MJ2? Sadly I think the answer is yes, but I thought I would ask to confirm.
Offline hashbaz
  • Grand Ancient One
« Reply #134 on: Mon, 13 August 2012, 00:12:52 »
Yep, to open the switch you have to desolder.
« Reply #135 on: Mon, 13 August 2012, 00:28:59 »
also, i think im going to hold back on charging shipping until i receive the items as it'll give me time to figure out the cheapest shipping option (especially for international)
any objections?
Offline DanGWanG
  • Higher Standards
« Reply #136 on: Mon, 13 August 2012, 00:34:10 »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #137 on: Mon, 13 August 2012, 00:50:30 »
Faster = better ;D
Offline damorgue
    • Personal portfolio
« Reply #138 on: Mon, 13 August 2012, 03:07:19 »
Wait a second, I haven't paid yet. So do we start paying Tuesday or should we have paid until then, and you intend to place orders then?
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #139 on: Mon, 13 August 2012, 06:03:28 »
You pay after the orders close, so yeah we start paying on Tuesday.
Offline Ian S
« Reply #140 on: Mon, 13 August 2012, 10:49:30 »
Just in case the form didn't work, I ordered 4 sheets of red .
Also:
Did you say these are $4 each?  So that's just under £3 each or £11.  Are you in the USA?  The import tax to the UK is nil if the order value is less that £15.  I'd rather not go over the £15 as the tax is 20% and there is also a £10 charge on top.
Thanks.
    • youtube
« Reply #141 on: Mon, 13 August 2012, 13:04:20 »
Ordered a red and green.
When you mentioned no combined shipping, that means for combining with other GB, right? Because no combining shipping for just 2 sheets seems a bit silly. I'm pretty sure this is how it is, but just had to clarify.
Offline alaricljs
« Reply #142 on: Mon, 13 August 2012, 21:24:23 »
Would be nice if they came in black... sometimes it's nice to not make a statement.
« Reply #143 on: Mon, 13 August 2012, 21:27:27 »
Fine, I'll bite. 1x pink, order submitted.
Offline Glissant
« Reply #144 on: Mon, 13 August 2012, 21:32:49 »
I'll bite too =).
« Reply #145 on: Mon, 13 August 2012, 22:18:56 »
yes, no combine shipping with my other gb
Offline OddOne
« Reply #146 on: Tue, 14 August 2012, 07:13:25 »
demik, Sent a pm in regards to adding one more yellow sheet.  Don't want to run out too soon!
|  CM Quickfire Rapid   |   Rosewill RK-9000BR  |  CM Quickfire Rapid  |
Offline damorgue
« Reply #147 on: Tue, 14 August 2012, 07:57:27 »
So, time to pay?
« Reply #148 on: Tue, 14 August 2012, 08:17:47 »
I'll let you know when to pay
Offline tinlong117
« Reply #149 on: Tue, 14 August 2012, 08:26:34 »
order submitted,
thanks
