Author Topic: Cant easily swap stems and springs if the switches have LEDs?  (Read 3058 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Fri, 10 August 2012, 10:14:54 »
Hey guys, i read somewhere that you can't swap a stem or spring on switches that have LEDs without completely desoldering the switch from the pcb, is this true? If so, why is it like that?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline alaricljs
  • I be WOT'ing all day...
Re: Cant easily swap stems and springs if the switches have LEDs?
« Reply #1 on: Fri, 10 August 2012, 10:18:46 »
On a PCB mount board you need only desolder the LED.  The LED leads go through the top and bottom switch housings and quite thoroughly ping it shut.
Filco w/ Imsto thick PBT
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Fri, 10 August 2012, 10:21:02 »
Ahh, this would make sense then. God damn me having to get the LED pure lol. Debating whether or not going from reds to ergo clears is worth it for all of the work :P
EDIT: Have you  or anyone here had any experience with the o-ring sound dampeners? I might snag a set of those instead if theyre worth it.
TOO BAD FOR YOU
Offline alaricljs
« Reply #3 on: Fri, 10 August 2012, 10:26:01 »
No personal experience w/ o-rings but plenty of people here have used them  red->ergo clear is *completely* different than red->red&o-rings.
Ergo clears have the sizable tactile bump of clear switches with the same spring as red/brown/blue switches.  Red w/ o-rings is just red with a squidgy bottom-out that's a little higher than normal.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Fri, 10 August 2012, 10:27:31 »
Yeah, I know, but I just dont trust myself with my ****ty soldering iron on the back of my brand new keyboard, know what I mean lol?
TOO BAD FOR YOU
Offline SmallFry
« Reply #5 on: Sun, 19 August 2012, 12:16:09 »
I'll do it for you if you have the parts. I have a good iron at home.
