Author Topic: KBT Pure / KBC Poker Carrying Case?  (Read 3062 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« on: Fri, 10 August 2012, 12:12:59 »
I think I saw something on here or somewhere else about a carrying case or sleeve for a poker or a pure. I myself have a pure and because it's so portable, I'd want to protect it while travelling. Anyone know anything about where I could find one, or something similar that would accommodate one? Thanks in advance.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: KBT Pure / KBC Poker Carrying Case?
« Reply #2 on: Fri, 10 August 2012, 13:34:18 »
There was also someone that got a poker chip hard case from somewhere like a walmart for quite cheap. Also fitting to put a Poker in a poker chip case lol.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #3 on: Fri, 10 August 2012, 15:09:33 »
If I can find some foam, I might just make one using one of those cases. Thanks for the idea :D
TOO BAD FOR YOU
