Author Topic: RAZER BLACK WIDOW KEY QUESTIONS  (Read 2085 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Sat, 11 August 2012, 11:53:10 »
i know i screwed up when i bought a razer instead of going for something else way back when- my bad. it just sits on a shelf these days and beings that i have some extra filco sets was wanting to swap out those hideous keys. the switches are fine, so i thought maybe i could frankenstein it. meaning the keys would look better, but the case..................:(
i read on here way back before we were violated that the space bar is not compatible with filco and the macro key is a weird size? if the space bar size is different can you tell me who would have the correct size and does it come in something other than black? i still have figured out the whole space bar 7x, 6x..................thing yet.
if the macro key is a weird size is it something say that can be easily massaged like getting a key from WASD and just sanding the sides down a little or is it completely a different bear?
figured my titanium skull would look pretty good with the led, but can't remember if the led is on top/bottom of the switch.
anybody have any knowledge to these boats?
on another note anybody catch wind of when wasd is coming out with their tenkeyless and why are the new white rosewell 9000's in hard to find with the brown switches? to bad they did not leave the plate red like the black cases.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Djuzuh
Re: RAZER BLACK WIDOW KEY QUESTIONS
« Reply #1 on: Sat, 11 August 2012, 11:58:28 »
Please don't use capital letters in the title x_x
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Sat, 11 August 2012, 12:01:19 »
gotcha.............my apologies
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 11 August 2012, 12:28:33 »
Like most iOne made board it use the 1.5,1,1.5,6,1.5,1,1,1.5 on bottom row. None of the other keys are non-standard. Easiest solution for keycaps is probably to source them from Cherry boards as those sizes are common on many models. Getting a winkeyless 1800 or similar for the 1.5 keys, and an 11900 for the 1x windows, menu and 6x space would be a way to go. Of course you are stuck with either black or white pretty much unless you get lucky and find some non standard colorway.
It's a lot of work for the BW in my opinion though. Personally I would just hock it on ebay and get rid of it and something better.
