Author Topic: Please recommend a keyboard for me  (Read 2733 times)
Offline tranceFusion
« on: Mon, 13 August 2012, 13:43:16 »
If someone can give me a recommendation or even a comprehensive list of keyboards that meet this criteria, that would be awesome:
1) Must be tenkeyless (or at least left side numpad)
2) Must have angled/split keys.
3) Not dome
I am looking for ergonomic reasons. Here's some keyboards I have tried (that don't meet all this criteria) just so you can get an idea..
- CM Storm Quickfire Rapid - really love it except that my shoulders are wide and the straight keys kill my forearms.
- Microsoft split natural - space bar really hard to push and killed my thumb.
- A4 Tech - angled keys with numpad on the left. For some reason the space bar bothers my thumb. I don't know why. Probably just because it's dome.
Also, FYI, I code for a living.. so lots of space bar, enter key, and punctuation going on..
Thank you!!!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Please recommend a keyboard for me
« Reply #1 on: Mon, 13 August 2012, 14:08:57 »
Not sure keyboards came with the numpad on the left side you might wanna get a tenkey pad. For question 2, can you explain this a little bit more.
Thanks
-Enzo Ferrari
Offline daerid
    • Rossipedia
« Reply #2 on: Mon, 13 August 2012, 14:25:26 »
If you're talking ergonomic (ala MS Natural series) style split keys, then your options are severely limited.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #3 on: Mon, 13 August 2012, 14:33:38 »
$600+ for that cherry split KB..Don't know that name at the moment -_-
-Enzo Ferrari
« Reply #4 on: Mon, 13 August 2012, 14:51:08 »
It doesn't have to be split.. It could be angled or elongated keys.. anything that will help keep my wrists from being bent inward while typing.
Offline Icarium
  • I AM A MONKEY!
« Reply #5 on: Mon, 13 August 2012, 15:13:30 »
As usually I will recommend a Kinesis.
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline daerid
    • Rossipedia
« Reply #6 on: Mon, 13 August 2012, 15:44:48 »
I've been using straight boards for years now. I used to use the MS Ergo series, but now they actually make my wrists hurt more. I don't know how/why people bend their wrists inwards when they type, I've never done that. Maybe it comes from having abnormally long fingers, Idunno....
« Reply #7 on: Mon, 13 August 2012, 17:38:55 »
G80-5000's are expensive. The utron (Topre keys?) is also expensive. So is the IBM M15.
If you want to wait a bit , we should have the ergoDOX made sometime, and that'll be good.
But your best bet is probably a kinesis
« Reply #8 on: Wed, 15 August 2012, 21:58:43 »
The Truly Ergonomic keyboard looks very promising. Is there a general consensus on this keyboard?
My only concern is the placement of the Enter key. It seems like it will be a lot of thumb'ing if I am using it for both space bar and enter key. I suppose I could re-map though.
Offline vorxaw
« Reply #9 on: Thu, 16 August 2012, 02:32:16 »
check out maltron, they are not the prettiest though :P
Offline hoggy
  • * Ergonomics Moderator
« Reply #10 on: Thu, 16 August 2012, 12:02:54 »
I'd happily recommend either the Kinesis or the Maltron.   If you are in the UK (or Europe), then you can hire a Maltron for forty pounds for a month.  If you are in the USA, then I believe you can buy a Kinesis with the option of returning it within sixty days.
Offline hoggy
« Reply #11 on: Thu, 16 August 2012, 12:06:38 »
For me, I find that the Kinesis has the edge as you can program it easily, and it's trivial to set it to dvorak.
That said,  Maltron are due to bring out a programable keyboard in the next few weeks.
