Author Topic: Filco Majesco 2 died suddenly  (Read 1967 times)
Offline Panther Modern
« on: Tue, 14 August 2012, 14:14:51 »
In the middle of use, my Filco ceased working altogether. 3 different computers are not recognizing it, and the lights on it are inoperable. Switching USB ports and trying a PS/2 adapter does nothing.
The seller says I can return it for a full refund, but it only cost me $70, so I would like to try and repair it if possible. Is this a simple USB cord malfunction, or could it be a more serious problem. What do you guys recommend I do?
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: Filco Majesco 2 died suddenly
« Reply #1 on: Tue, 14 August 2012, 14:16:57 »
Don't put it in the dishwasher or washing machine.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #2 on: Tue, 14 August 2012, 14:20:49 »
Mine has the same issue, got a new usb cord and it worked.. PM Limmy as he might have an extra usb cable.
thanks
-Enzo Ferrari
« Reply #3 on: Thu, 16 August 2012, 18:27:17 »
So can I use any USB cord as a replacement, or do I need a certain type? Are there any guides for this that you guys can direct me to?
Offline xyril
    • Youtube Channel (full of typing and gaming vods)
« Reply #4 on: Thu, 16 August 2012, 22:28:55 »
any tutorials for a USB rpleacement?
« Reply #5 on: Fri, 17 August 2012, 12:25:36 »
Any USB cable should work, but you'll need a compatible connector to connect it to the filco PCB. I don't have a filco (and I'm away from my keyboards this week, so I can't look it up on my cmstorm) but I suspect you can just use a 0.1in connector. There was a post on GH that had the model number of one, so you could look it up on mouser, but I can't remember where.
You could, of course, solder directly to the pins on the PCB, but It's not as good a solution, and may have mechanical reliability issues down the line (Even with the good cable gland filco uses).
