Author Topic: thread icons with more contrast  (Read 6450 times)
Offline limmy
« on: Wed, 15 August 2012, 16:25:25 »
I tend to read the thread where I posted/contributed. And currently those thread are distinguished by small icon, which in my opinion lacks contrast to distinguish them from others. I think more contrast would be better for better viewing experience. Maybe different color or bigger icon?
Here is what I mean.
I am going to attach two versions of the icon gifs that I used in case you are interested in using them.
« Last Edit: Wed, 15 August 2012, 16:27:05 by limmy »
Offline Djuzuh
Re: thread icons with more contrast
« Reply #1 on: Wed, 15 August 2012, 16:33:01 »
useless post is useless, but +1.
Offline rknize
    • metaruss
« Reply #2 on: Wed, 15 August 2012, 17:16:27 »
Done.  I had to edit 12 icons across 3 themes, but there you go.
Russ
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #3 on: Wed, 15 August 2012, 18:38:31 »
rknize from Chicago?!  Are you attending our gathering?!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #4 on: Wed, 15 August 2012, 18:39:02 »
it's almost as if all the themes should inherit from some... "default" theme...
Offline DanGWanG
  • Higher Standards
« Reply #5 on: Wed, 15 August 2012, 18:42:21 »
Kinda like the master slide on PowerPoint...amirite?
Offline rknize
    • metaruss
« Reply #6 on: Wed, 15 August 2012, 18:43:12 »
Well, the icons may be different for the different color schemes.  I orangified a lot of the ones there were blue in default, but many I haven't changed.  Indeed, it would be nice if they worked like more of an overlay.
Russ
Offline rknize
    • metaruss
« Reply #7 on: Wed, 15 August 2012, 18:43:56 »
Unfortunately I won't be able to make it.  Hopefully the next time!
Russ
Offline mkawa
« Reply #8 on: Wed, 15 August 2012, 19:13:41 »
i was totally just teasing you :D but that's actually a really good idea.
Offline limmy
« Reply #9 on: Wed, 15 August 2012, 20:38:12 »
Thank you very much for the update. It is much better!!!
Just one more thing. Could you change the icons where there are a lot of pages? A group buy section is where there are plenty of thread with many many posts. I would like the group buys that I participated to stand out from the rest.
Thank you again.
Edit: My suggestion was accepted and the icons are now more distinguishable. Thank you very much!
« Last Edit: Thu, 16 August 2012, 17:14:04 by limmy »
