Author Topic: FILCO Red Top Ninja TKL  (Read 3136 times)
Offline kaiserreich
  • HHKB Elite
« on: Thu, 16 August 2012, 03:33:15 »
So sexy. Saw it at iomania.
I can't find any more info about it.
180,000kr won. Thats about 160-170 USD
« Last Edit: Thu, 16 August 2012, 03:40:53 by kaiserreich »
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: FILCO Red Top Ninja TKL
« Reply #1 on: Thu, 16 August 2012, 06:19:10 »
Demik has one :)
Offline Rafen
« Reply #2 on: Thu, 16 August 2012, 06:23:05 »
You could just buy a normal black Filco and just paint the case if you can't find one. I have done this to about 3 keyboards so far and they have all turned out really nice.
Offline Tenkey
« Reply #3 on: Thu, 16 August 2012, 18:52:00 »
Just did a search on taobao, heres the link of it http://item.taobao.com/item.htm?id=16327355036&ali_trackid=2:mm_14507416_2297358_8935934:1345160942_3z2_1674678945, blue and brown switches i believe. You can always ask Lin for taobao goods ;)
Offline kaiserreich
  • HHKB Elite
« Reply #4 on: Fri, 17 August 2012, 06:10:03 »
I don't have to. :P
But Taobao is marking them up a bit more. which makes it as much as a Realforce.
Offline jcrouse
« Reply #5 on: Fri, 17 August 2012, 06:54:25 »
Demik has one :)
And mine is on it's way across the pond now. It should be here late next week. Should look totally awesome with RA2 and grey mods.
Offline kaiserreich
  • HHKB Elite
« Reply #6 on: Fri, 17 August 2012, 07:34:39 »
Please take a picture of it with the RA set.
Offline rao2100
« Reply #7 on: Sat, 18 August 2012, 00:11:11 »
Hi Rafen, what paint did you use? Using brush or spray?
| KMAC LE Vintage Blues | LZ-S Ergo Clears | Filco TKL MJ2 Ninja Reds | CM QFR - Blues | IBM Model M SSK 1991 |
