Author Topic: Realforce 87u Dust Cover  (Read 2627 times)
Offline MarkPharaoh
« on: Thu, 16 August 2012, 04:28:34 »
Hi guys, is there anything out there right now that is better priced than the $30 EK covers? Finding it a bit hard to stomach ~$40 shipped for a simple cover.
Thanks.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline longweight
  • philanthropist
Re: Realforce 87u Dust Cover
« Reply #1 on: Thu, 16 August 2012, 04:54:11 »
Nope, that is a pretty good price in my mind. You might find something on Taobao but that will work out to be more expensive.
Offline feng
« Reply #2 on: Thu, 16 August 2012, 10:54:55 »
For US customers, EK's prices are pretty good actually. Although you can find cheaper on Taobao, the shipping would cost more than the cover itself.
Offline therecorder
« Reply #3 on: Thu, 16 August 2012, 11:14:26 »
Yes, and at least you'll be certain that the cover will fit correctly.
(I, however, use a light, folded, terry cloth hand towel (in an appropriate color :)) to cover my Realforce, and shake it out every so often.)
« Last Edit: Thu, 16 August 2012, 11:19:30 by therecorder »
Offline MarkPharaoh
« Reply #4 on: Thu, 16 August 2012, 12:25:01 »
Thank you for the replies!
