Author Topic: What is the difference between orange alps and pink alps?  (Read 2414 times)
Offline 486
« on: Thu, 16 August 2012, 21:13:51 »
Could someone please outline the main differences between orange and pink alps.
Also, why are pink alps more desired than orange alps?
Offline Magna224
Re: What is the difference between orange alps and pink alps?
« Reply #1 on: Fri, 17 August 2012, 12:28:50 »
I heard that the difference was that the orange ALPS have they grey switchplate and the pink have the white. So it should be the same difference as blue ALPS are to white.
Offline Icarium
  • I AM A MONKEY!
« Reply #2 on: Fri, 17 August 2012, 13:45:05 »
Meaning what exactly? Where is ripster when you need him? :D
Where can the pink alps be found? I'm pretty sure I have orange, maybe I can compare them.
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
  • Live long and prosper
« Reply #3 on: Fri, 17 August 2012, 13:50:53 »
Aren't orange ALPS found in old Apple keyboards? I vaguely recall owning one a while ago...
tp thread is tp thread
Offline 486
« Reply #4 on: Fri, 17 August 2012, 17:33:29 »
I've spotted a Wang 724 with Pink (or as webwit calls them, salmon alps) Alps.
I'm just guessing they are rare because not many were made. I still think brown alps are the rarest. If I find a dead IBM convertable, I'm desoldering the Brown Alps.
