Author Topic: Linux question.  (Read 3509 times)
Offline Viz
Linux question.
« on: Fri, 17 August 2012, 09:12:46 »
So, I'm wondering if there's any fellow linux users here. My more specific question is; What do you use the F-keys for?
I've been thinking of using them for binds. For example: F1 = Launches rxvt-unicode.
Is there anyone here doing something similar? And; Is there any cons of doing this?
I'm a big CLI guy, so I mostly use the asdf+++ keys.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: Linux question.
« Reply #1 on: Fri, 17 August 2012, 09:49:41 »
Wow, I guess I do really ignore my F-row keys. For my binds, I end up just using Winkey combinations. I have e17 set up with 9 virtual desktops (3x3 grid) on each monitor, and use Win+[qweasdzxc] to navigate those, with Win+R opening the Everything launcher, and Win+T opening urxvt.
Maybe I should make use of the F-row keys.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Icarium
  • I AM A MONKEY!
Re: Linux question.
« Reply #2 on: Fri, 17 August 2012, 10:08:38 »
The F keys are really far away and are actually used in some programs that's why I don't have any fancy bindings for them. :)
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Re: Linux question.
« Reply #3 on: Fri, 17 August 2012, 11:17:19 »
I almost never use the function keys.
If you didn't know already, in Linux console mode, Alt-Fx key switches between virtual consoles. If you have X running, then one of them usually goes (back) to X.
Some window managers for Linux/X therefore have Alt-Fx mapped to switching between workspaces, per default, and I used to have it that way for years. These days, I have them mapped on Alt-numeric row instead, so that I  don't have to stretch too far.
I also used to map Previous track, Play/Pause and Next track to Scroll Lock, Pause/Break, and Print Screen, respectively for my mp3 player.
Offline Anynoupy
  • French Fries
Re: Linux question.
« Reply #4 on: Fri, 17 August 2012, 14:41:29 »
Just to let you know, there is a Linux thread :)
As for the F-keys, same as Icarium, not binding them ^^
Offline Djuzuh
Re: Linux question.
« Reply #5 on: Fri, 17 August 2012, 14:53:56 »
I use F5 to refresh GH.
AAAAAAAND that's it.
Offline Viz
Re: Linux question.
« Reply #6 on: Fri, 17 August 2012, 14:59:36 »
Djuzuh: I use R to refresh. Vimperator masterrace!
Other guy: I prefer the awesome window manager, I could maybe make the bind F-keys script launch once I launch X? That way I can keep the funcionality of tmux.
Offline Djuzuh
Re: Linux question.
« Reply #7 on: Fri, 17 August 2012, 15:04:39 »
I will jump onto vimperator or the fork one day.
Offline Viz
Re: Linux question.
« Reply #8 on: Fri, 17 August 2012, 15:06:19 »
I hope you will! The mouse makes my arm hurt, I only use it when I play games, edit photos or... Am lazy  :D
Offline Djuzuh
Re: Linux question.
« Reply #9 on: Fri, 17 August 2012, 15:17:15 »
I switched to a trackball, because my mouse hurted too.
Offline davkol
  •  Post Editing Timeout
Re: Linux question.
« Reply #10 on: Sat, 18 August 2012, 05:54:49 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 14:31:43 by davkol »
Offline poxeclipse
  • Hit me with music ... yes, me friend
Re: Linux question.
« Reply #11 on: Sat, 18 August 2012, 07:34:51 »
I use Alt+Fn to switch between workspaces. Alt+1, 2, ... are for switching between tabs in the terminal. I'm running Fedora 15.
