Author Topic: key cap dyeing  (Read 9666 times)
Offline Wintermoot
key cap dyeing
« on: Fri, 17 August 2012, 14:13:08 »
hello GH first time poster here.
I,m planning to dye the caps on this old KB I get lying around here and I would like to know what sort of dye I should be using.
I was thinking of using cloth dyes.
« Last Edit: Fri, 17 August 2012, 15:27:18 by Wintermoot »
WASD V1 MX Blue|Keycool 84 MX Red
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: key cap dying
« Reply #1 on: Fri, 17 August 2012, 14:33:52 »
Someone dyed a set of PBT keys and wrote a how-to on that. Will search for it when I get to my PC.
-Enzo Ferrari
Offline MMB
Re: key cap dying
« Reply #2 on: Fri, 17 August 2012, 14:36:50 »
key cap dying
« Reply #3 on: Fri, 17 August 2012, 15:04:10 »
Hahaha! I thought your keycap was dying. As in not alive. You mean dyeing. LOL
Offline Wintermoot
Re: key cap dying
« Reply #4 on: Fri, 17 August 2012, 15:19:02 »
http://geekhack.org/index.php?topic=27237.0
thanks but the thing is I don't have access to RIT dye's can any old cloth dyer do the job?
  • Live long and prosper
Re: key cap dying
« Reply #5 on: Fri, 17 August 2012, 15:22:01 »
hehe...
As for using clothing dye, I wouldn't think it would be as effective, but I suppose it can't hurt to try, could it?
tp thread is tp thread
Re: key cap dying
« Reply #6 on: Fri, 17 August 2012, 15:36:38 »
hehe...
Don't melt your keycaps, though.
Re: key cap dyeing
« Reply #7 on: Fri, 17 August 2012, 15:39:54 »
Oh, yeah... probably should have emphasized that.   :))
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: key cap dyeing
« Reply #8 on: Fri, 17 August 2012, 17:46:27 »
People have tried things other than RIT, but I don't think anything has been found that works as well.  In particular, some tried Dylon and the results were very washed out.  If your keys are not PBT you need to be super careful about melting them with too much heat.
Re: key cap dyeing
« Reply #9 on: Fri, 17 August 2012, 20:28:11 »
My experience has been that RIT powder works great on PBT, but that the liquid is all but useless on plastic.
Black was awesome but all the other dark colors I tried came out muddy and uneven.
Bright colors like scarlet and sunshine orange were particularly nice.
I have tried to dye ABS more than once, with a few pitiful successes and a lot of failures.
The effective temperature of the dye may be a few scant degrees below than the soften/melt temperature of ABS, but the range and tolerance is very small. There is no point in mentioning numbers, because your results will vary according to your equipment. I will say for certain that it is well below the boiling point.
You can only trust trial and error. Go to a thrift store and buy some $1 junk keyboards for experimentation.
Without an ounce of sarcasm (Transportation Secretary Sean) Duffy then added, “It fits any budget to do a road trip.”
Offline Phagocytosis
Re: key cap dyeing
« Reply #10 on: Sat, 18 August 2012, 14:57:37 »
Rit dye is the way to go.  The only issue my brother had when he did it was that he didn't let all of the alcohol evaporate when cleaning the keys before dyeing so some of them had an uneven sheen.
Leopold TKL - Ghetto Green
Apple Extended II - Orange Alps
Offline KeyboardRookie
Re: key cap dyeing
« Reply #11 on: Sat, 18 August 2012, 15:11:49 »
Is there any custom dye-sub company? I have a lot of keycaps with no engraving. It will be great if I can print what I want.
Just dyeing cannot satisfy me.
« Last Edit: Sat, 18 August 2012, 15:14:17 by KeyboardRookie »
I'm in chronic intoxication to keyboards,
Re: key cap dyeing
« Reply #12 on: Sat, 18 August 2012, 15:20:59 »
you can try asking imsto, but you'd have to ship them out to china.
Offline modulor
Re: key cap dyeing
« Reply #13 on: Mon, 20 August 2012, 15:38:57 »
I've read 'metal spraypaints' such as Krylon X-Metals and Duplicolor Metalcast work well with ABS plastics.  I haven't seen any examples yet of them on keycaps, so I may have to try it out myself.  Basically, the spraypaint acts like a vinyl dye and is absorbed into the plastic.  Here is an example on a classic gameboy to get an idea:
This was an ol' grey brick sprayed with one coat of X-Metals.  You can see how it absorbed into the plastic, but left the printed text intact.  The process was supposedly quick, drying in less than 10 minutes.  I think this could potentially work well for keycaps too, and could be a better alternative to coloring ABS caps, since it is sensitive to the higher temperatures of RIT dyeing.  PBT is more resilient in that regard, though I've heard the reports of uneven coating.  I wonder if these particular paints will take to PBT as well, only one way to find out  :) for science!  Thoughts?
NP-R (soon) | 21XX (soon) | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-1000HBU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline hashbaz
  • Grand Ancient One
Re: key cap dyeing
« Reply #14 on: Mon, 20 August 2012, 15:47:41 »
That GameBoy photo looks really promising.
Re: key cap dyeing
« Reply #15 on: Mon, 20 August 2012, 16:50:22 »
Please keep us posted on the short-term and long-term prognosis on this process.
This could be huge!
Offline peachesenregalia
Re: key cap dyeing
« Reply #16 on: Mon, 20 August 2012, 17:39:24 »
My experience has been that RIT powder works great on PBT, but that the liquid is all but useless on plastic..
Just want to attest to the general ****tyness of the liquid dye for key caps. I've tried a few different colors on PBT and it simply doesn't take.
Good feeling of oneness.
Re: key cap dyeing
« Reply #17 on: Mon, 20 August 2012, 23:31:02 »
Did anyone successfully took PBT keycap color modification yet?
Re: key cap dyeing
« Reply #18 on: Tue, 21 August 2012, 00:23:54 »
I have seen some successful PBT dying. Perhaps the best was an HHKB that had been dyed, which looked really good.
Offline modulor
Re: key cap dyeing
« Reply #19 on: Tue, 21 August 2012, 11:34:20 »
I'll test out some of the various methods, perhaps this weekend if I can get all the materials together by then.  I should be able to get both brands of paint easily, and I already have some RIT powder dye.  I'll try to use a few different types of keycaps as well for variety.
