Author Topic: IBM PC/AT (Model F AT)...awesome looking condition.  (Read 3486 times)
Offline AKIMbO
  • HHKBro
« on: Sat, 18 August 2012, 21:20:50 »
http://www.ebay.com/itm/140828824331?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
^Check it out.  I'd bid on it if I didn't just acquire my 3rd PC/AT keyboard.
| KBD75 (box reds)
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: IBM PC/AT (Model F AT)...awesome looking condition.
« Reply #1 on: Sat, 18 August 2012, 21:21:43 »
ooosh, delete this thread <3
;D
Offline AKIMbO
  • HHKBro
« Reply #2 on: Sat, 18 August 2012, 21:35:42 »
Lmao....it's my favorite make/model kb.  Dunno if my signature gives it away.
| KBD75 (box reds)
Offline jwaz
  • * based mod
« Reply #3 on: Sun, 19 August 2012, 00:58:51 »
I really want to get one to try out (maybe mod) because I really like the switches on these better than my Model M. Hard to find a good deal on one though...
Offline Rarusu
« Reply #4 on: Sun, 19 August 2012, 13:28:34 »
Sadly not a german qwertz. Trying hard to find a Model F PC/AT (i love them *sigh) with german qwertz but no luck so far.  :(
Offline N8N
« Reply #5 on: Sun, 19 August 2012, 14:10:33 »
Hoping everyone's poor this week.  Really want to try an F but didn't worry about scoring one back when they were hitting trash piles...  i mean, Ms had a better layout, and most keyboards were pretty good...
Offline AKIMbO
  • HHKBro
Re: Re: IBM PC/AT (Model F AT)...awesome looking condition.
« Reply #6 on: Sun, 19 August 2012, 16:17:31 »
I keep saying...model f's will change your life bro.  So much lighter than model m's....makes cherry blues feel like a pauper's switch.
| KBD75 (box reds)
Offline JBert
« Reply #7 on: Sun, 19 August 2012, 16:38:31 »
Heh, seems the F and J keys got some "home spot markers" burned in though... You want them, except when you're going for a Colemak layout.
The storage list:
Currently ignored by: nobody?
[/SIZE]
« Reply #8 on: Sun, 19 August 2012, 16:47:31 »
There is no doubt that the stock Model F XT has the best feel, undoubtedly since it was manufactured when IBM was charging $350 1984 dollars for it, about what a dot-matrix printer cost, and about as complicated.
I can't abide the layout of an F XT, or even an F AT, for that matter, because I use both number and arrow keys all the time, and switching between them with NumLock is a nightmare.
However, for me, a modded F-122 terminal board gives me everything I want, plus a bonus set of function keys and a dozen more spares at the top.
When you take it apart to move barrels and springs around to achieve a very-near-ANSI layout, you might as well do a bolt mod. It is much easier than a Model M bolt mod, and you can use normal nuts and bolts from the corner hardware store.
While you are at it, do a floss mod, too, and you will have a exquisitely delicate behemoth that is acceptable in polite company.
Unfortunately, the F-122s have now become as expensive as the others, and harder to find.
- Oliver Willis 2026-08-01
« Reply #9 on: Sun, 19 August 2012, 18:37:42 »
I need to resurrect my bolt-mod wiki for the F-122.
The F XTs and F ATs have what I would call "sliding force-fit tabs" (for lack of a better term) at the top and bottom of the curved plates. It is only mildly difficult to slide them back together, but the F-122s have 3 rows of tabs, including 1 in the middle that requires some bending and forcing of the plates.
I am a big strong guy, but I only have 2 hands, and it is extremely difficult to put one of these beasts back together without a strong helper.
My bolt mod cuts the pesky tabs off and uses only about a half-dozen bolts. Unlike a Model M bolt mod, where there are many of them that you tighten to only finger-tight, for gently adjusting the feel and ping, on the Model F mod I employed rubber and metal washers and screwed them down just as tight as I could for complete rigidity.
Offline poxeclipse
  • Hit me with music ... yes, me friend
« Reply #10 on: Sun, 19 August 2012, 19:13:23 »
Model F is lighter and faster, indeed. My problem is the space bar being too hard for me. I opened mine when I cleaned it, but I had no idea, and no time to think about, how to make the space bar lighter. Underneath there is just a steal wire held between two plastic guides. Now, I don't think I want to open it again the second time.
So, if somebody has any idea how to make the spacebar lighter, or already tried it, please, share with us.
« Last Edit: Sun, 19 August 2012, 19:19:45 by poxeclipse »
Offline AKIMbO
  • HHKBro
« Reply #11 on: Sun, 19 August 2012, 20:16:48 »
It's an easy mod.  If you look at the space bar stabilizer wire, it is bent into a downward v shape.  You bend the stabilizer wire into a less sharp v shape ( ie.  Place the v shape on your knee and bend the two highest points of the stabilizer wire downwards towards the ground).  It only needs to be bent by a few degrees to significantly reduce the actuation force required for the space bar.  There is a wiki on it somewhere on this site.
If you really want to attempt this mod and can't find the wiki, i will snap a few photos tomorrow and write a short how to.
| KBD75 (box reds)
Offline poxeclipse
« Reply #12 on: Mon, 20 August 2012, 05:46:52 »
AKIMbO, thank you, it's enough. I'll try it. I was concerned of modifying the length of the stabilizer, at the beginning.
« Last Edit: Mon, 20 August 2012, 06:18:17 by poxeclipse »
Offline poxeclipse
« Reply #13 on: Mon, 20 August 2012, 06:58:00 »
I got mine for $5. It is in pristine condition, almost. It was sitting in a basement for 27 years, with other 7 IBM model F boards.
What I want to say, is that eBay is not the only source. Just look around, especially check the recycling companies.
« Last Edit: Mon, 20 August 2012, 07:07:46 by poxeclipse »
Offline poxeclipse
« Reply #14 on: Mon, 20 August 2012, 07:06:08 »
Another question for AKIMbO. The F and J key caps don't have nibs. There is a way to add them ?
Offline AKIMbO
  • HHKBro
« Reply #15 on: Mon, 20 August 2012, 07:17:21 »
Yes...I actually do this to all my F ATs (add home row nubs).  I just source the F & J keys from model m keyboards.  Unicomp sells single keys for extremely cheap and so does clickykeyboards.com.
| KBD75 (box reds)
