Author Topic: LZ ANODIZED ALUMINUM  (Read 30893 times)
Offline DrugER
  • JACKASS@KBDmania
    • JACKASS76@WORDPRESS.COM
« on: Sun, 19 August 2012, 00:40:07 »
I am honored to introduce 'LZ ANODIZED ALUMINUM HOUSING SERIES'
1. 86&87 LAYOUT HOUSING
    : You can make 87 or 86 KEYBOARD , ONLY Choice  two other wk or wkless  'reinforcement board' at same housing.
2. MINI LAYOUT HOUSING
   : It's called LZ-MINI (is based MX-MINI)
YOU CAN SEE MORE INFORMATION AT "http://lzlife.tistory.com"
IF U HAVE A PRIVATE QUESTION, WHENEVER SEND A 'PM' 2 ME.
#Our LZ TEAM(TEAM NAME IS 'REDLINE') will be announced Pricing and detailed specifications soon.
'86 & 87 LAYOUT HOUSING'  based on the price of roughly about 230-250 U.S. dollars(Include PCB BOARD, BUT not INCLUDE shipping fees and V.A.T.)
« Last Edit: Sun, 19 August 2012, 05:59:29 by DrugER »
RED-LINE.KR
Re: LZ ANODIZED ALUMINUM
« Reply #1 on: Sun, 19 August 2012, 00:52:53 »
I've wanted an lz mini for my mx mini ever since I saw it.
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #2 on: Sun, 19 August 2012, 01:09:28 »
So pretty!
Offline DrugER
  • JACKASS@KBDmania
« Reply #3 on: Sun, 19 August 2012, 01:48:57 »
you can get lz-mini housing. !!!
someone help you can get it. not only me.
RED-LINE.KR
Offline kaiserreich
  • HHKB Elite
« Reply #4 on: Sun, 19 August 2012, 03:40:07 »
Where do I sign up?? :p
Offline nntnam
« Reply #5 on: Sun, 19 August 2012, 04:06:04 »
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline damorgue
    • Personal portfolio
« Reply #6 on: Sun, 19 August 2012, 05:41:49 »
Nice flat edges and no extra details. This looks like it would be much cheaper than the others, nice. Any price figures yet?
Offline nntnam
« Reply #7 on: Sun, 19 August 2012, 06:11:49 »
Oh, saw the price. Count me in for a 86 version please :P. Sound like I will need some switches and springs.  :-* :-* :-*
« Last Edit: Sun, 19 August 2012, 06:13:27 by nntnam »
Offline DrugER
  • JACKASS@KBDmania
« Reply #8 on: Sun, 19 August 2012, 06:31:47 »
yes, we offer housing, plate and PCB ONLY.
RED-LINE.KR
Offline damorgue
« Reply #9 on: Sun, 19 August 2012, 06:32:07 »
For only the case, it is way too expensive for such a simple case. Then I read that a PCB is included, which could justify the price a bit more. Does the PCB have a controller and diodes soldered?
Offline AKIMbO
  • HHKBro
« Reply #10 on: Sun, 19 August 2012, 07:20:43 »
LZ Mini is mine!
| KBD75 (box reds)
Offline longweight
  • philanthropist
« Reply #11 on: Sun, 19 August 2012, 07:44:34 »
$250 is way to expensive for an aluminium case?
Offline damorgue
« Reply #12 on: Sun, 19 August 2012, 07:59:28 »
With that design, yes. They have a hefty margin since there are few milling steps involved. It also doesn't require as many different tools to make this one, without chamfers etc. This design has a higher margin than the MKC case.
They do include a PCB of some sorts, which I guess bring the price to more reasonable levels. I wonder what kind of PCB it is and how complete it is. A PCB with soldered controller and diodes has a notable cost, and if it is included the price makes more sense.
Offline cactux
  • Topre Knight
« Reply #13 on: Sun, 19 August 2012, 08:02:57 »
^ He did not mention anything abut Hardware, so IMO is just the case plus the pcb
[FS]☠ The temple lol ->HERE<-
Offline limmy
« Reply #14 on: Sun, 19 August 2012, 08:07:29 »
There are two designs. One is LZ-MINI and the other is LZ87. Both design has aluminum plate which goes inside the aluminum case. Are these designs that simple?
Offline nntnam
« Reply #15 on: Sun, 19 August 2012, 08:16:48 »
He stated that the price is for the case, pcb and plate. I'm still confused about the LZ mini, is it just the case for MX mini?
Offline damorgue
« Reply #16 on: Sun, 19 August 2012, 08:21:05 »
If no controller is included, which one is supposed to be used? A teensy, a Chamelon or something else. I guess my question is: Is it up to us to make things work or is it provided?
And does the PCB include anything but traces?
Offline kaiserreich
  • HHKB Elite
« Reply #17 on: Sun, 19 August 2012, 08:22:32 »
I saw in the blog page that the 84key winkeyless is coming up. Is it possible to order that?
Offline nntnam
« Reply #18 on: Sun, 19 August 2012, 08:26:46 »
So many question, I think we'd better wait for the new instruction/information from thread owner ;D.
Offline limmy
« Reply #19 on: Sun, 19 August 2012, 08:31:31 »
As far as I know, the PCB is designed to use Aikon controller. Not sure if they are soldered on, but many times the controller and other necessary parts are offered as package.
Anyways.. the price of $250 seems to be lower than what I thought. KMAC group buy price was in that range and I heard KMAC project team worked pretty hard to get that price range plus the order size was larger in KMAC GB hence possibly better price tier than LZ series.
@damorgue:
Could you answer my question above? Is the design that simple?
Here are more pics on how the aluminum housing looks like.
2413-0
2415-1
You can also see that the controller is soldered on. The controller is called Aikon controller and it uses Atmega chip.
Image source: http://www.kbdmania.net/xe/4791858
« Last Edit: Sun, 19 August 2012, 08:49:14 by limmy »
Offline damorgue
« Reply #20 on: Sun, 19 August 2012, 08:48:58 »
It is simpler, with fewer steps and tools needed. That said, since the PCB is included as well as a controller, that makes the price of the case more like 200 which is in line with what you would expect.
Edit: Does the mini case work the same; as in, included pcb and not made to fit some other model?
« Last Edit: Sun, 19 August 2012, 08:51:01 by damorgue »
Offline limmy
« Reply #21 on: Sun, 19 August 2012, 09:04:30 »
The cases and plates would only be compatible with A87 PCB and MX-MINI PCB. They are not made to be compatible with Filco or any other mass-produced keyboards.
Edit: Getting key caps for these boards will be an issue for many people who are not collector of Cherry vintage key caps. Many require Cherry style stepped Capslock and x1.5 bottom modifiers. I don't know if flat Capslock can be used, but I didn't see a single case where such Capslock is used.
« Last Edit: Sun, 19 August 2012, 09:22:12 by limmy »
Offline nntnam
« Reply #22 on: Sun, 19 August 2012, 09:50:58 »
^ the keycaps are the reason I'm seeking for a korean custom keyboard. However, looking for a 1x modifier in white and dolch color scheme is not easy, I don't know if they exist. In the other hand, for the white on black cherry caps, the 1.5 modifers are even rarer than the 1.25x one.
Offline ekw808
  • Ekw
« Reply #23 on: Sun, 19 August 2012, 09:54:27 »
That mx mini case is MINE
[One Keyboard at a time]
Offline Tenkey
« Reply #24 on: Sat, 25 August 2012, 18:20:09 »
Where is the winkeyless version!!!!
Offline dirge
« Reply #25 on: Sun, 26 August 2012, 03:27:43 »
Could you provide an ISO.layout also?
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
« Reply #26 on: Sun, 26 August 2012, 03:32:33 »
koreans don't use ISO.
so chances are, nope.
86 = winkeyless
1.5|1x|1.5
so the case will look the same as the mock ups
Offline WhiteFireDragon
    • youtube
« Reply #27 on: Sun, 26 August 2012, 11:05:19 »
I would love one of those mini's, but normal PBT caps won't fit. It'll be too hard to find that right shift.
Offline nntnam
« Reply #28 on: Sun, 26 August 2012, 11:18:57 »
Every G80-1800 will have that short right shift. Btw, it has been a while without any update. Is this dead?
    • youtube
« Reply #29 on: Sun, 26 August 2012, 11:42:56 »
Not KBC or imsto PBT sets.
Offline Tenkey
« Reply #30 on: Sun, 26 August 2012, 13:13:50 »
86 = winkeyless
1.5|1x|1.5
Nope theres a 84 version on there site thats why im asking
Offline kriminal
« Reply #31 on: Sun, 26 August 2012, 23:21:32 »
mx mini????? anybody link me that?
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Tenkey
« Reply #32 on: Mon, 27 August 2012, 16:03:45 »
Why is this thread dead.....
Need UPDATES :(
Offline jcrouse
« Reply #33 on: Mon, 27 August 2012, 16:06:41 »
Well, this is the first I've seen the LZ Mini case and have to agree. I'll be all over one of these for my MX Mini when they are available.
Offline kriminal
« Reply #34 on: Mon, 27 August 2012, 22:41:25 »
mx mini? info anybody?
« Reply #35 on: Thu, 30 August 2012, 08:59:27 »
At least the imsto ones are cherry profile.
I'm interested in updates, too.
Offline ekw808
  • Ekw
« Reply #36 on: Thu, 13 September 2012, 20:06:40 »
UPDATESSSSSS
Offline emptythecache
  • out.
« Reply #37 on: Thu, 27 September 2012, 09:21:07 »
YES, UPDATES PLEASE.
(sorry to anyone who got excited that my post might've been the OP. I nudged him by pm, hopefully he comes back!)
Offline DrugER
  • JACKASS@KBDmania
« Reply #38 on: Thu, 27 September 2012, 11:11:00 »
we are ready to Our webpage 4 Geekhacker.
u can buy at webpage soon.
But, we don't make webpage completely yet.
NOW, We think about  'how we provide LZ SERIES' at GEEKHACK and WORLDWIDE.'
plz wait...coming soon.
http://red-line.kr
RED-LINE.KR
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #39 on: Thu, 27 September 2012, 11:17:04 »
http://red-line.kr
Thanks for the headsup and link...I will be camping your site now :)
-Enzo Ferrari
Offline modulor
« Reply #40 on: Thu, 27 September 2012, 12:16:01 »
Exciting news and thanks for the updates!  ...so if I've read this correctly, these cases (LZ Mini more specifically) will come with the PCB with controller, or is that something that has to be acquired or owned separately?
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline phetto
  • HHKB JP
« Reply #41 on: Mon, 01 October 2012, 13:22:38 »
Noob question, can someone help me and show me where I can buy all components to build a board with this?
REALLY interested.
Offline modulor
« Reply #42 on: Mon, 01 October 2012, 15:29:41 »
REALLY interested.
According to DrugER above, they will be made available on their website ( http://red-line.kr ) some point in the near future, but it seems that it'll only be available in Korea until they organize a way to make it available worldwide, possibly though a GB here.  As far as I can tell, they will offer the case, plate and pcb with controller, so you'll have to acquire mx switches from another source and solder them on.  Just keep an eye on this thread for upcoming news. :D
Offline phetto
  • HHKB JP
« Reply #43 on: Mon, 01 October 2012, 15:34:13 »
^ So this package he's showing her, only need switches for it to work? 7bit have switches so that won't be a problem.
Thanks
Offline alaricljs
  • I be WOT'ing all day...
« Reply #44 on: Mon, 01 October 2012, 15:37:53 »
Don't forget the stabilizers
Filco w/ Imsto thick PBT
  • Live long and prosper
« Reply #45 on: Mon, 01 October 2012, 15:38:35 »
How would one go about getting one of these:
http://lzlife.tistory.com/entry/LZ-S-RED-CARBON-EDITION
tp thread is tp thread
Offline ekw808
  • Ekw
« Reply #46 on: Mon, 01 October 2012, 15:49:37 »
I'm pretty sure this is a case, and there is no PCB, you have you find your own MX MINI first before being able to use this case. It  has the option to be centered stem CAPS LOCK or the left aligned IIRC.
Offline modulor
« Reply #47 on: Mon, 01 October 2012, 15:50:52 »
Indeed...forgot about them!  Do you happen to know if the plate supports Cherry, Costar or both?
Offline modulor
« Reply #48 on: Mon, 01 October 2012, 15:53:18 »
DrugER mentioned that they would have the PCB below:
It's my understanding that said PCB would have a controller built in, but it hasn't been confirmed yet if it will all be one package (though it seems so).
Offline phetto
  • HHKB JP
« Reply #49 on: Mon, 01 October 2012, 15:57:01 »
Where do I get the mx mini then?
