Author Topic: Best Artisan Mousepad for Razer Deathadder/Abyssus?  (Read 6736 times)
Offline inSeason
« on: Mon, 20 August 2012, 02:12:43 »
I've been looking all over the net and I cannot find the information I'm looking for. Which Artisan Mousepad is best for the Razer Deathadder/Abyssus?
I have a Hayate M Soft and it is starting to ware. I'm currently looking to replace it with another Artisan pad.
Offline hcry4
  • HHKB Hoarder
Re: Best Artisan Mousepad for Razer Deathadder/Abyssus?
« Reply #1 on: Mon, 20 August 2012, 09:59:53 »
A good replacement is probably the Hayabusa.
Offline inSeason
« Reply #2 on: Tue, 21 August 2012, 12:22:47 »
Is that comparable to the SHIDEN-KAI XSOFT??
Offline hcry4
  • HHKB Hoarder
« Reply #3 on: Tue, 21 August 2012, 13:31:38 »
The Hayabusa is like a slight upgrade to the Hayate and feels about the same. Shiden-Kai has a slick glass coating. Both are very good but the Hayabusa is probably a safer bet if you prefer the feel of the Hayate.
Offline xJaPx
  • Oh, Herro!
« Reply #4 on: Tue, 21 August 2012, 13:40:00 »
i really like my hien, its a bit rough, bit it almost polishes the feet as you use it , making it move quite nicely
| Poker MX Red |
Offline inSeason
« Reply #5 on: Tue, 21 August 2012, 13:53:27 »
I do prefer pure cloth pads. Thanks for the advice. The Hayabusa seems to be a softer version of the Hayate which I think is best. I do not like the feel of hard mats.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6 on: Thu, 23 August 2012, 23:16:21 »
Raiden just came out and it doesn't have the directional change with vertical movement vs horizontal movement.  So in short, if you want:
Faster than Hayate =>  Raiden
Slower than Hayate => Hayabusa
Offline akuJIWA
  • Lock 'N Load!
« Reply #7 on: Sat, 25 August 2012, 03:06:49 »
It's either the Hayabusa, or Hien. How is that hayate? How does it feel compare to a SS mousepad?
The Cheat - B/R/B ; Clear switch with 62g springs
quit
