Author Topic: Someone with a G80-3000 who could make some measurements for me?  (Read 1806 times)
Offline damorgue
    • Personal portfolio
Does anyone know what colours go to which pins of the PS/2 in a G80-3000? I think I have the older version of the PCB. I always thought the colours of the PS/2 were standardized but apparently they aren't. Could someone open theirs?
Best would be if someone in here has one with the old version of the PCB and could give me this:
How are these pins connected to the PCB? There are 5 solderingpoints. Labeled from top to bottom A-E. Could someone give me something like
1-A
2-B
3-D
4-C
5-E
6-not used
That is just an example. Thanks. It would be greatly appreciated.
Offline dirge
Re: Someone with a G80-3000 who could make some measurements for me?
« Reply #1 on: Wed, 22 August 2012, 12:15:13 »
Opened mine up and used the multimeter on it.
plug - pcb
2 - 1 - white
3 - 2 - green
6 - 3 - yellow
4 - 4 - black
4 - 5 - black
my pcb has numbers the bottom is 1, that's what I've just put in this reply.  So I think for you 5 = A etc.
Hope that helps.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline damorgue
« Reply #2 on: Wed, 22 August 2012, 12:17:17 »
GREAT
thanks dirge, I have been trying to figure out which of the thick traces were ground and 5V and which of the thin ones were data and clock.
Edit:
I am going to add this here so that I can have both on the same screen as reference.
Pin 1    +DATA
Pin 2    Not connected
Pin 3    GND
Pin 4    Vcc
Pin 5    +CLK
Pin 6    Not connected
« Last Edit: Wed, 22 August 2012, 12:20:20 by damorgue »
Offline damorgue
« Reply #3 on: Wed, 22 August 2012, 12:21:46 »
pin# - what it is supposed to do >>> pcb - colour of wire
pin2 - nothing >>> 1 - white
pin3 - GND >>> 2 - green
pin6 - nothing >>> 3 - yellow
pin4 - Vcc >>> 4 - black
pin4 - Vcc >>> 5 - black
Something seems a bit off here, data isn't used?
« Last Edit: Wed, 22 August 2012, 12:26:14 by damorgue »
Offline damorgue
« Reply #4 on: Wed, 22 August 2012, 12:28:38 »
Perhaps the image is describing the socket and not the cable and as such it is mirrored? That makes much more sence.
That would make it:
pin1- data >>> 1 - white
pin4 - Vcc >>> 2 - green
pin5 - clock >>> 3 - yellow
pin3 - ground >>> 4 - black
pin3 - ground >>> 5 - black
Edit: dirge, can you confirm that you took the image above and numbered the pins as if the image was depicting the end of the cable?
« Last Edit: Wed, 22 August 2012, 12:32:58 by damorgue »
Offline dirge
« Reply #5 on: Wed, 22 August 2012, 13:26:40 »
Yes I took the image as if I was looking at the end of the plug. :)
