Author Topic: Keycap ID Request - CM Quickfire Rapid Pro  (Read 4261 times)
Offline swagpiratex
« on: Thu, 23 August 2012, 15:03:40 »
So i got a chance to check out the Rapid Pro yesterday and really liked the keycaps they had on the keyboard.  Anyone that owns or tried the keyboard know what the material is made out of?
Right now typing on my Das Professional Model S, and want to replace the ABS keys with blank keys in that material, if possible.  Thanks!
Re: Keycap ID Request - CM Quickfire Rapid Pro
« Reply #1 on: Thu, 23 August 2012, 23:19:33 »
I'm almost 100% sure it's "normal" ABS Plastic. That said, sometimes ABS plastic is really nice.
I would recommend replacing with PBT, mainly 'cause it's awesome.
Offline DaClownie
  • Handsome Devil
« Reply #2 on: Thu, 23 August 2012, 23:49:52 »
Yea, CM Quickfire Rapid keys get shiny rather quick. My space bar on the Quickfire held up worse than the spacebar on my Blackwidow.  That's not to say it's not a great keyboard and all.
For what it's worth, I'm replacing my main 37 typing keys with PBT side printed, and the modifiers and the like will remain ABS until I find a full PBT set I want to invest in.
Offline swagpiratex
« Reply #3 on: Thu, 23 August 2012, 23:49:57 »
Yea after doing some research, the pictures of the PBT keys look really, really nice.
Is there someone currently selling PBT sets? I'm looking for thick blank black PBT's. I've read that imsto does thick ones.
Does this vendor carry them? http://www.vendio.com/stores/E-sports-Gaming-equipments/
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #4 on: Thu, 23 August 2012, 23:53:19 »
Yes, qtan and feng here carry KBC's PBT keycap sets.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline swagpiratex
« Reply #5 on: Fri, 24 August 2012, 01:14:42 »
My search-fu is pretty good, but couldn't find the KBT caps you mentioned.
Are these comparable to imsto PBT?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=98
« Reply #6 on: Fri, 24 August 2012, 09:50:08 »
That's Qtan's store, and I believe most or all of the PBT he carries is from KBC
http://www.vendio.com/stores/E-sports-Gaming-equipments/category/pbt-key-caps/catId=3982960
The second set appears to be Ducky's PBT set.
They all compare to imsto's PBT, but aren't as thick. They also have a different profile.
Offline swagpiratex
« Reply #7 on: Fri, 24 August 2012, 10:02:51 »
Thanks for the heads up. I'll keep my eyes peeled for the next group buy from imsto.
