Author Topic: Switch Examples?  (Read 1633 times)
Offline TGShadow69
Switch Examples?
« on: Mon, 27 August 2012, 15:38:37 »
I was wondering if there was anything like these,
http://www.ebay.com/itm/Ducky-Keychain-w-Blue-MX-Switch-Orange-Keycap-/330780187439?pt=PCA_Mice_Trackballs&hash=item4d04091b2f
but for other switch types, or where could one get examples of switch types might be a better question to ask.  I am wondering this because I am debating between buying a keyboard with browns or reds in them.
« Last Edit: Mon, 27 August 2012, 15:40:10 by TGShadow69 »
Filco Majestouch [Blacks], Filco Majestouch 2 Tenkeyless [Browns]
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Switch Examples?
« Reply #1 on: Mon, 27 August 2012, 15:44:44 »
You could always just buy some switches on thier own.
Offline Velma
« Reply #2 on: Mon, 27 August 2012, 15:47:09 »
Sadly i dont think there is any other way than to buy both boards, try them lightly to see wich you prefer and then use your right to return x-item within x days if still in mint condition (different companies have different policies afaik) to return the one you didnt want and get your money. ive heard though that you dont have this right in all countries, but here in sweden you always get a so called "open deal" wich means you have the right to return something within 3-5 days if its still in mint condition.
Offline TGShadow69
« Reply #3 on: Mon, 27 August 2012, 15:48:29 »
Thats perfect thanks, although i still kind of like the idea of having them on a key-chain, but this is perfect.
« Reply #4 on: Mon, 27 August 2012, 15:54:12 »
Just buy the keychain, pull out the blue one and put the other one inside. Easy.
