Author Topic: Razer Naga Thumb LED Gets Warm  (Read 8104 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Mon, 27 August 2012, 20:02:12 »
Hello so I've owned a Razer Naga for almost about a year now.  I've always left the lights off because I find the thumb grid lights gets warm after a while.  It's not hot enough that it's uncomfortable, but it's definitely warm enough to make me sweat.  And overall a bit annoying.
By default the software group the scroll wheel light with thumb grid light, then the razer logo light is on its own.  So if I turn off the thumb grid it will turn off scroll wheel light.  Does anyone know is there a way to hardware mod it so I can only have the scroll wheel light on?  At the moment my guess is I might have to permanently disable the thumb light in the hardware then turn everything on in the software to achieve that.
Here's a video I saw on YouTube which shows the internals, the part I'm focusing on is start at the 1:00 mark
Any hardware guru out there might know?
Offline WatchMaker
Re: Razer Naga Thumb LED Gets Warm
« Reply #1 on: Sat, 22 September 2012, 07:43:37 »
I keep all the light on my naga turned off.  i figure the cooler the mouse is the better it should work
btw i'd go back to the old 3.0.2 drivers the new synapse suck
I'm able to toggle the icon & numpad lights seperately
Offline Hyde
« Reply #2 on: Wed, 26 September 2012, 15:39:55 »
Yeah I usually keep the light off also.  I find the issue I have now is that they link the scroll and thumb pad together, so I think I have to hardware modify it to get just the scroll wheel light up.
