Author Topic: Anyone know of a Linux symbolic set?  (Read 2723 times)
Offline __red__
« on: Tue, 28 August 2012, 11:31:06 »
As we all know Linux has multiple layers usually activated by alt or shift-alt .
Has anyone seen a keyset which has these symbols on the keys?
Thanks
Red
(edit: In case it isn't clear, I mean the following symbols):
±²³´µ¶·¸¹°­½÷åòôùõéïðÛÝÜáóäæçèêëì»§úøãöâîí¬®¯þ¡À£¤¥Þ¦ª¨©ß«Ñ×ÅÒÔÙÕÉÏÐûýüÁÓÄÆÇÈÊË̺¢ÚØÃÖÂÎͼ¾¿
« Last Edit: Tue, 28 August 2012, 13:41:53 by __red__ »
Offline never4getthis
Re: Anyone know of a Linux symbolic set?
« Reply #1 on: Tue, 28 August 2012, 14:02:49 »
not sure at all. Look into foreign language keycaps like french norwegian... (they have those symbols and you might be able to assemble a set). Otherwise make your own at WASD
Typist
Noppoo Choc Mini (Cherry MX Blue)
Offline damorgue
    • Personal portfolio
« Reply #2 on: Tue, 28 August 2012, 14:06:10 »
Some of those are from different Nordic countries, but I don't think you will find one which carries all of those. That is a lot of weird symbols. As stated, WASD keyboards could make them for you, I think that is your best bet.
