Author Topic: Where to buy pbt keycaps  (Read 4160 times)
Offline TGShadow69
« on: Thu, 30 August 2012, 18:46:59 »
I was just wondering where would be a good place to buy pbt keycaps that has a good variety or choices.  ive been a lurker for a about 2 years or so(maybe a little less) and have always wondered where to get them and can never find them.
Filco Majestouch [Blacks], Filco Majestouch 2 Tenkeyless [Browns]
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Where to buy pbt keycaps
« Reply #1 on: Thu, 30 August 2012, 18:59:18 »
IMO the best ones are available from IMSTO, check his subforum.
Offline TGShadow69
« Reply #2 on: Thu, 30 August 2012, 19:10:41 »
sweet ill take a look, thanks.
Offline swagpiratex
« Reply #3 on: Thu, 30 August 2012, 22:08:28 »
Right now it seems he has the thick grey and blue ones in stock. Other colors will be coming in later months, if you can wait.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Fri, 31 August 2012, 09:08:52 »
Or if you want white set, join my groupbuy now. Currently offering them in Russian, and have a vote open for other layout choices.
« Reply #5 on: Fri, 31 August 2012, 16:44:07 »
Keyboard manufacturer Ducky makes PBT keysets, that are sold separately from some retailers.
Black or white. Engraved or burned legends. The language options are a bit limited, though.
