Author Topic: would you suggest a 2.0 speaker set?  (Read 9741 times)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« on: Sat, 01 September 2012, 02:34:06 »
I'm looking for a 2.0 speaker set to place on my desktop. I don't have a lot of space so ideally the speakers shouldn't be too big and possibly not too ugly :) What would be your suggestions?
thanks geekhackers!
Offline BoxWithADot
Re: would you suggest a 2.0 speaker set?
« Reply #1 on: Sat, 01 September 2012, 02:55:50 »
I have some logitech z313 speakers (they're 2.1, they have a subwoofer) and they work fine for me. They're relatively small, and the subwoofer isn't terribly large either, it just sits below my desk. They're also pretty cheap ($50 I think). I'm sure the audiophiles of geekhack will have better suggestions, but for watching movies and listening to music while I code/study they're perfectly adequate haha.
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #2 on: Sat, 01 September 2012, 03:03:59 »
Do you have space for something like the M-Audio AV40?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #3 on: Sat, 01 September 2012, 03:15:35 »
yeah, I might consider a 2.1... just have to find a place for the sub.
unfortunately not.
I was looking at the Bose Companion, but they say they are overpriced for the quality
Offline csm725
    • http://csm725.com
« Reply #4 on: Sat, 01 September 2012, 06:49:22 »
They are VERY overpriced.
Can we have a pic of your setup to see what kind of speakers would fit?
Thanks.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #5 on: Sat, 01 September 2012, 07:21:01 »
oh gosh, desktop is a mess right now :)
basically I don't have room for speakers that are too wide, but I could place anything tall and narrow (such as Creative GigaWorks T40 or T20 http://us.store.creative.com/Creative-GigaWorks-T40-Series-II-Speakers/M/B001S14DYO.htm ). The alternative would be to find a nice 2.1 set and put the subwoofer somewhere under the desktop, I had a couple of them but they tend to be bass-monsters but overall sound quality is not that good especially at low volume. I'm just looking for a clean/nice sound, I don't need high volume and ultra-bass.
thanks for your help
Offline csm725
    • http://csm725.com
« Reply #6 on: Sat, 01 September 2012, 11:55:02 »
The Corsair SP2200/SP2500 are good. May be overpriced in Europe though.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #7 on: Sat, 01 September 2012, 12:36:05 »
I double checked the speakers size, they are not actually that big, they seemed bigger on photo. I can probably fit them and they are reasonably priced. Thanks!
Offline PointyFox
« Reply #8 on: Sat, 01 September 2012, 13:28:07 »
USB speakers...They must have a DAC/amplifier built-in.  I wouldn't imagine they sound too good.
Offline csm725
    • http://csm725.com
« Reply #9 on: Sat, 01 September 2012, 13:43:34 »
The AV40s aren't USB...?
They are self powered, but they still need a DAC (which would optimally be a sound card).
Their amp is more than adequate.
Offline phetto
  • HHKB JP
« Reply #10 on: Sat, 08 September 2012, 18:28:33 »
I had D'feldt audio engine 5, best pc speakers I've owned, before that I had the Harman Kardon Soundsticks II, both are very good speakers and in different price ranges.
The ones I first mentioned is obviously better, one of the best speakers you can buy. - If you dont buy regular speakers and dac. But the HK plays well too.
Go to a local store and listen! :-D
Today I own a basic speaker kit, 2.1 $50-ish, since I use HDMI to my hometheatre speakers, which works better for me.
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #11 on: Sun, 09 September 2012, 05:25:59 »
If you're looking for cost-effective, I had a pair of Logitech R10s that I got for $15 that actually sounded surprisingly good.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #12 on: Sun, 09 September 2012, 08:33:32 »
It's surprising that there aren't actually "medium level" pc speakers. I mean you can get a logitech set for $15 or audioengine for $300... where's the middle ground?
Offline ekw808
  • Ekw
« Reply #13 on: Sun, 09 September 2012, 08:45:52 »
Audio Engine 2 for 200, or klipsch 2.1s for around 100
[One Keyboard at a time]
Offline phetto
  • HHKB JP
« Reply #14 on: Sun, 09 September 2012, 09:11:02 »
Eh, I just figured that you needed a high-end solution for the maximum Eros Ramazzotti-experience ;)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #15 on: Sun, 09 September 2012, 09:32:43 »
that's definitely not the music I like...
Offline phetto
  • HHKB JP
« Reply #16 on: Sun, 09 September 2012, 09:47:17 »
Joking mate. But seriously, there isnt much in between those price ranges, you should probably aim for something like Creative Gigaworks t20 or t40.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #17 on: Sun, 09 September 2012, 09:47:31 »
You can try to find a used logitech z2300. The sub is huge, but the satellites are pretty small.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline AKIMbO
  • HHKBro
« Reply #18 on: Sun, 09 September 2012, 10:09:00 »
Check out the Swan M10 computer speakers.
| KBD75 (box reds)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #19 on: Sun, 09 September 2012, 10:37:06 »
lovely!
Offline mars-bar-man
« Reply #20 on: Wed, 19 September 2012, 14:39:52 »
Creative T20/T40's? I've got the T20's and they're brilliant! Can't see myself getting any others really, I'm not a massive audiophile so they do just fine.
KBC Poker w. MX Blues
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #21 on: Wed, 19 September 2012, 15:23:27 »
I have the T40's and they sound quite good. Sure, they do not pump out as much bass as the €300,- Onkyo 5.1 receiver + speaker combo set I have back home, but It is still enough, especially after you burn them in after a few hours of use.
I have now been using them for 2 weeks, listening music for around 3-6 hours a day and I noticed the sound has gotten a lot fuller and the bass has gotten stronger. I even had to turn them back down a little bit.
One reason for me to get the T40's over the T20's is the stands. While the T40's are higher, the screw-on stand makes them very stable. I have to push the top 10cm to the side to go over it's center of gravity. Otherwise it will just bounce back to it's original position. The only way to knock them over is to flip the table. :P
At first I thought I would use them without the grills, but I kind of like the understated look standing right next to my 13inch laptop.
I am studying abroad, so my current appartment has only a 1x1m desk. Maybe I can make some pictures later this week, but I will have to upload them later.
« Last Edit: Wed, 19 September 2012, 15:26:13 by JaccoW »
|||My other keyboards :
x
|D嶰k Legend Frost|Keycool 87 LE|Leopold FC660M|FC 210TP|Raptor K1 Gaming|Duck Orion TKL|My keycaps & sets
Offline jpm804
  • KeyCap Assasin
« Reply #22 on: Wed, 19 September 2012, 18:17:22 »
^^^ I have them and love them much better than a 5.1 setup... They dont take up much space and they also look & sound great.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #23 on: Wed, 19 September 2012, 23:42:22 »
Pricey, but awesome - http://www.crutchfield.com/p_091XSBOOK/Focal-XS-Book-Music-System.html?tp=252
Good, too - http://www.crutchfield.com/p_807LESMS/Audyssey-Lower-East-Side-Media-Speakers.html?tp=252#customer-reviews-tab
I'm using the XS Books myself right now and am a huge fan.  Of course, I like focal's line up in general...
I also have a pair of MAudio AV40s that I always forget I own for some reason.  They're ok, good for the price but the range is a little dicey and they like to crackle on the high end.  I'd still sell them to you if you'd like for $100 plus shipping, though. But it'd be international, soooo yeah.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #24 on: Thu, 20 September 2012, 02:11:31 »
I've read a couple of reviews, they say sound is good but one of the front speakers hisses. can you confirm? that scares me a little
these are awesome! I believe I might have found the right ones!
thanks, but as you said international shipping sucks. I can find the AV40 for �130, so not really expensive.
« Last Edit: Thu, 20 September 2012, 02:24:47 by Matt3o »
Offline jpm804
  • KeyCap Assasin
« Reply #25 on: Thu, 20 September 2012, 02:58:18 »
I've had them for about 3-4 years now and never heard any hissing... not sure how much they go for now but I got mine for $90 which I thought was a good deal.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #26 on: Thu, 20 September 2012, 03:15:14 »
great deal I'd say! I can find them for �120
Offline suprsmo
  • Sydney, Australia
« Reply #27 on: Thu, 20 September 2012, 03:46:57 »
^^ Bought a pair of these to replace my aging and subpar logi 5.1 system..
Absolutely love them
http://www.pccasegear.com/index.php?main_page=product_info&cPath=567_602&products_id=12299
Also got the stands that these guys sell as well.. and they made a decent difference.. even just to lift the sound to your ears..
Poker
QFR
Offline DarkShot
  • Professional Procrastinator
« Reply #28 on: Thu, 20 September 2012, 12:16:38 »
I can also attest to Audioengine speakers. I've got the A5s which are the A2's larger sibling. They sound great and the fact that the amplifier is built in was why I wanted them.
If you really want 2.1 set than the Swan M10s are also supposed to be fantastic for computer speakers.
If you can honestly put the money towards them, do so. It'll definitly be worth it in the end especially if you spend hours at your desk and don't use headphones.
