Author Topic: New to the mechanical keyboards  (Read 3173 times)
Offline TPG18
« on: Sun, 02 September 2012, 04:23:46 »
I bought the CoolerMaster Quickfire Rapid blue switches a couple of weeks ago and I am loving it. Much better than the rubber domes.
I have one problem though. I have the backspace key which squeaks at times when I press it. I have posted on other forums about what I have to do, which was to lube the stabilizers. People told me that white lithium grease was good to use, but I just wanted to get a confirmation if these products are correct. I have asked on other forums but never got an answer.
http://www.jaycar.com.au/productView.asp?ID=NA1015
http://www.altronics.com.au/index.asp?area=item&id=T3122
Re: New to the mechanical keyboards
« Reply #1 on: Sun, 02 September 2012, 05:01:15 »
Welcome to Geekhack!
This.
Although most of the products listed here are in the US, you should be able to find equivalents in Aus.
  • Live long and prosper
« Reply #2 on: Sun, 02 September 2012, 08:00:57 »
tp thread is tp thread
Offline nullstring
« Reply #3 on: Sun, 02 September 2012, 08:23:47 »
You should not that reseating the stabilizer may get rid of your problem as well.
I would try that before bothering to purchase the lubricants.
Offline TPG18
« Reply #4 on: Sun, 02 September 2012, 14:40:26 »
How would I go about reseating the stabilizers?
