Author Topic: Do keyboard roofs work?  (Read 3322 times)
Offline karljs
« on: Sun, 02 September 2012, 23:33:02 »
Title says it all---do keyboard roofs really reduce or eliminate the need to regularly remove keys and clean things out, or are they more of an aesthetic accessory? Any keyboards I keep at home for long ends up with cat hair in them, which I'm tired of cleaning.
Offline TheProfosist
  • Custom Layouts Only!
Re: Do keyboard roofs work?
« Reply #1 on: Mon, 03 September 2012, 00:47:55 »
Yes it keeps dest and dirt off if them or anything from directly falling on them. I used to use roofs all the tim but recently ive just been forgetting to put them back on everytime i leave the computer for a lengthly peroid. I guess that because i have a standing desk now that my cats cant get up on.
Offline PointyFox
« Reply #2 on: Mon, 03 September 2012, 00:51:46 »
If you have animals that sit on the keyboard when you're not using it; yes.  Otherwise no.  Most of the stuff that ends up in a keyboard falls off/out of you when you are using it.
« Reply #3 on: Mon, 03 September 2012, 03:40:29 »
My house is somewhat dusty - nothing much I can do about it except clean regularly (which sets my hay fever off).
My Ducky SHine came with a plastic dust cover which I try to leave on as often as possible - definitely overnight and when I am at work during the day.
It doesn't stop the odd dust particle or hair falling on the keyboard during normal use, but I am hoping that it will stop needless avalanches of dust burying the keyboard in the short term.  That was a slight exaggeration, but anyway.
I have not had mine for long enough to notice any significant difference, but so far so good.  Can't be bad.
Offline quake4mhg
« Reply #4 on: Mon, 03 September 2012, 03:54:58 »
It works.  My house is dusty too. I don't feel safe because no PCB cover inside KBT Race. It is an expensive peripheral to me  ;D
« Reply #5 on: Mon, 03 September 2012, 03:59:22 »
Apart from being relatively expensive, I also do not want my mechanical keyboards to fail before their time.  Each key switch is supposed to last 50 million key strokes - I would prefer not to have it clogged with dust before then.
Offline MarkPharaoh
« Reply #6 on: Mon, 03 September 2012, 04:12:20 »
Of course it reduces the frequency of cleanings. Dust particles are always floating in the air. The more often your keyboard is covered, the less it's exposed to dust.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline silat
« Reply #7 on: Mon, 03 September 2012, 04:30:54 »
I highly recommend the one I use:
http://www.fentek-ind.com/keyboard-cover.htm
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline RiGS
« Reply #8 on: Mon, 03 September 2012, 07:26:30 »
It is quite easy to clean the switches from time to time with something like deoxit. You do not even need to open those switches. Pesonally I have never seen a Cherry switch filled with dust.
Offline 1stGenRex
« Reply #9 on: Mon, 03 September 2012, 07:29:00 »
I use the cover that came with my Filco.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10 on: Mon, 03 September 2012, 07:41:43 »
Thanks for that one, finally one that can house my Deck Legend!
|||My other keyboards :
x
Offline RiGS
« Reply #11 on: Mon, 03 September 2012, 07:52:20 »
I find the original plastic cover that comes with Filco keyboards sufficient. Maybe I'm just too cheap to buy an acrylic one.
« Last Edit: Mon, 03 September 2012, 07:54:09 by RiGS »
Offline dirge
« Reply #12 on: Mon, 03 September 2012, 07:56:07 »
I use a bar towel
Also handy to have if you spill anything.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
« Reply #13 on: Mon, 03 September 2012, 08:31:51 »
If you have a Focus 2001 I have a nice hinged cover that I will sell you.
- D Trump 2026-10-24
Offline TurdFurgusand
« Reply #14 on: Mon, 03 September 2012, 17:05:36 »
Yes, it keeps the dust off of mine
Offline _js_
« Reply #15 on: Thu, 04 October 2012, 14:28:43 »
I never used a roof before my HHKB Pro 2, partly because they were out of stock at EK and partly because I didn't like the full sized roof design as much as for the HHKB.  But, in any case, not that I have a roof, I really like it, and it definitely does keep dust off your board, especially if you put the roof on for many hours (or days) at a time--such as if your board is at work (as is my case).  Mostly, though, it's just cool!  :)
HHKB Pro 2, AEK II
« Reply #16 on: Thu, 04 October 2012, 18:45:06 »
I'm not worried about dust (So my plates get a little dandruffy) but I'd definitely use a roof for travel, to protect the keycaps.
