Author Topic: Split ergo keyboard concept  (Read 6603 times)
Offline Netsu
« on: Mon, 03 September 2012, 10:03:21 »
« Last Edit: Mon, 03 September 2012, 10:06:46 by Netsu »
Offline Icarium
  • I AM A MONKEY!
Re: Split ergo keyboard concept
« Reply #1 on: Mon, 03 September 2012, 10:12:14 »
Hm, I'd say there is too much pinkywork.
Edit: Do you have any 6x7 boards available you want to build this with?
« Last Edit: Mon, 03 September 2012, 10:16:16 by Icarium »
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline Netsu
« Reply #2 on: Mon, 03 September 2012, 10:57:19 »
pinkywork
Got used, I'm a emacs user :D
And seriously — I'll be grateful to any feedback and critique.
Suggest an alternative solutions?
Nope, I don't. But plan to order their development yet.
By the way, can you tell me where I can find information about the required opensource microcontroller with usb port for programmable keyboard? Whether there is an established standard?
P.S. : Please excuse my poor English  :rolleyes:
« Last Edit: Mon, 03 September 2012, 11:04:15 by Netsu »
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Mon, 03 September 2012, 12:41:41 »
Have seen the ErgoDox? It's in the process of coming to fruition. It will be fully remap-able and will be available in kits. Check it out!
Offline Netsu
« Reply #4 on: Mon, 03 September 2012, 12:58:17 »
ErgoDex has no mechanical keyswitches, alas.
Offline Djuzuh
« Reply #5 on: Mon, 03 September 2012, 13:13:10 »
he talked about ergodox.
Check is out, it's a userdriven project on this forum.
Offline Netsu
« Reply #6 on: Mon, 03 September 2012, 13:17:43 »
Thanks and sorry for mistake! :)
Offline Icarium
  • I AM A MONKEY!
« Reply #7 on: Mon, 03 September 2012, 13:40:46 »
I still like your idea because with Tipros it could be created quite cheaply.
Offline pyro
« Reply #8 on: Mon, 03 September 2012, 13:49:58 »
Space position seems weird. Why is it so far left and not in the bottom row?
Offline Icarium
  • I AM A MONKEY!
« Reply #9 on: Mon, 03 September 2012, 15:59:37 »
Not in the bottom row is fine if you chose the right heights for your caps.
Offline Netsu
« Reply #10 on: Mon, 03 September 2012, 16:36:13 »
Variant with less pinkywork ( but a few ugly maybe ? )
UPD: Both keyboard layouts are designed to support both Dvorak (Programmer Dvorak too) and Qwerty.
You read my mind!
Right and bottom place is occupied by the modifier keys, because they are used in combinations with other buttons. And they a shorter then spacebar. While the spacebar is directly under the letter keys.
Thanks, it seems a good idea!
« Last Edit: Mon, 03 September 2012, 16:46:28 by Netsu »
Offline Pyrolistical
« Reply #11 on: Wed, 05 September 2012, 20:56:40 »
Offline Netsu
« Reply #12 on: Thu, 06 September 2012, 11:12:36 »
Nice! Like your design and implementation, and also like to use trackpad too  :cool:. And can you tell me where you ordered keycaps, plz?
« Reply #13 on: Thu, 06 September 2012, 14:51:37 »
I took half from a das keyboard and the rest I just ordered them from wasd keyboard.
It was expensive but fine for a one off kb
Offline Lanx
« Reply #14 on: Sat, 08 September 2012, 02:23:10 »
you should line up 1/q and p/0 to keep the maxtrix layout
Offline Netsu
« Reply #15 on: Thu, 13 September 2012, 21:25:03 »
Inspired by Maltron and ErgoDox:
...but this's quite another keyboard layout  :)
Or a bit simplified:
« Last Edit: Mon, 17 September 2012, 22:22:13 by Netsu »
Offline Netsu
« Reply #16 on: Tue, 02 October 2012, 06:45:24 »
And yet another split matrix keylayout idea:
