Author Topic: [PRODUCTION] Cherry MX PCB and plate mount stabilizer sets.  (Read 27793 times)
Offline alaricljs
  • I be WOT'ing all day...
« on: Tue, 04 September 2012, 15:56:40 »
Cherry MX stabilizers in PCB or plate mount.  This is September 1st if you're jet-lagged  :)
OVER  --  Parts received, space bar wires being bent.
What is on offer:
Cherry MX 2x unit stabilizer sets.  Custom bent spacebar wires for any spacing you need (6.25/7/??).
86 key boards use 4 2x and 1 7x stab
101 key boards use 7 2x and 1 7x stab
Please PM your order as such:
# PCB
# PLATE
# WIRE (SIZE)
The WIRE includes *just* that: a wire, bent to your length specs.  You will need a PCB or PLATE mount stabilizer to put it in.  7x is the key cap size, 4.5" is the distance stem to stem (on center).  Stem to stem in inches is the safest bet if you have an odd request.
Typical 84/86key board is 4 2x + 1 7x:
5 PCB
1 WIRE (7x)
Typical 101key board is 7 2x + 1 7x:
8 PCB
1 WIRE (4.5")
Random order:
10 PLATE
1 WIRE (6.25x)
1 WIRE (7x)
2 WIRE (3x)
Pricing:
PCB Mount 2x stabilizer  (+~$10 shipping split between the buyers):
1-24:       $.58
25-99:     $.54
100-249: $.50  <--- We are here
PLATE Mount 2x stabilizer (+~$10 shipping split between the buyers):
1-49:       $.76
50-99:     $.66  <--- We are here
100-249: $.55
WIRE - custom bent  to your specs
$1 per wire
Shipping to you is additional and we'll work that out when we get there.
« Last Edit: Tue, 02 October 2012, 21:01:22 by alaricljs »
Filco w/ Imsto thick PBT
Offline alaricljs
Re: [GB] Cherry MX PCB and plate mount stabilizer sets.
« Reply #1 on: Tue, 04 September 2012, 15:56:48 »
Final collected orders 9/11/2012 midnight (sorta)
75 Plate
191 PCB
60 Wires
14 orders, lowest: $3.76, highest: $26.93
« Last Edit: Tue, 11 September 2012, 00:07:09 by alaricljs »
Offline alaricljs
« Reply #2 on: Tue, 04 September 2012, 15:56:53 »
« Reply #3 on: Tue, 04 September 2012, 16:07:17 »
Order sent.
5 PCB
1 WIRE (7x)
Offline alaricljs
« Reply #4 on: Wed, 05 September 2012, 10:42:52 »
Uh guys, what happened to all the interest?  This GB is gonna collapse without more orders.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Wed, 05 September 2012, 10:49:49 »
I will order some plate versions to replace the asstastic costar on my Chicony... and some extras so I can do the same on any board with costar I happen to acquire in the future.
« Reply #6 on: Wed, 05 September 2012, 10:50:18 »
Offline ekw808
  • Ekw
« Reply #7 on: Wed, 05 September 2012, 10:53:00 »
18 pcb
5 Wire 7x
2 Wire 4.5x
[One Keyboard at a time]
Offline alaricljs
« Reply #8 on: Wed, 05 September 2012, 10:58:18 »
lysol:  costar/cherry plate mount footprint is completely different.  You sure you want to attempt that?
« Reply #9 on: Wed, 05 September 2012, 13:34:11 »
I am going to be doing switch swap and paint the plates anyway. It should not be too hard to modify the plate for it I don't think. If it dosen't work out I am only out a few dollars.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #10 on: Wed, 05 September 2012, 13:40:26 »
I need these for the following:
1x KMAC winkeyless
1x Cheat winkey 1.5x1x1.5x
1x LZ87SE winkeyless
1x K-Mini
1x Plate mounted Poker
Can anyone recommend me what I need?  I'm not sure whether I need Plate or PCB
Offline sth
  • 2 girls 1 cuprubber
« Reply #11 on: Wed, 05 September 2012, 13:52:53 »
pmed for 3 7x wires and 15 stabilizers.
Offline alaricljs
« Reply #12 on: Wed, 05 September 2012, 13:56:54 »
KMACs are PCB, images I've seen of A87 are PCB, images of the Cheat are PCB,
« Reply #13 on: Wed, 05 September 2012, 21:37:28 »
But they'll still work on the phantom, right?
Offline alaricljs
« Reply #14 on: Wed, 05 September 2012, 21:48:33 »
Phantom has a combo cutout for costar and Cherry.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #15 on: Thu, 06 September 2012, 06:45:45 »
I need enough to do 3 Kmac winkeyless.
-Enzo Ferrari
Offline alaricljs
« Reply #16 on: Thu, 06 September 2012, 07:37:22 »
15 PCB
3 WIRE (7x)
Offline alaricljs
« Reply #17 on: Thu, 06 September 2012, 08:20:40 »
If you have not PM'd me your order then it never happened.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: [GB] Cherry MX PCB and plate mount stabilizer sets.
« Reply #18 on: Thu, 06 September 2012, 08:50:54 »
-Enzo Ferrari
Offline damorgue
    • Personal portfolio
« Reply #19 on: Thu, 06 September 2012, 15:11:04 »
Was the IC thread removed? I had calculated what I wanted and posted it in there and now I can't find it.
Offline alaricljs
« Reply #20 on: Thu, 06 September 2012, 15:59:59 »
Was locked, but you should have no issue finding it...  it's in Making stuff... found it
Offline Game Theory
« Reply #21 on: Thu, 06 September 2012, 18:59:13 »
5 x pcb
1 x 6.25x for KMAC with winkeys?
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline Tenkey
« Reply #22 on: Thu, 06 September 2012, 19:35:19 »
pm sent
Offline alaricljs
« Reply #23 on: Fri, 07 September 2012, 08:24:41 »
Ok folks, we've got the majority of previously interested parties ordering and some new faces.  I don't want to leave this running forever.  Sept 12th is the cutoff as of this moment.
Offline alaricljs
« Reply #24 on: Fri, 07 September 2012, 12:31:54 »
Bumped the end date forward to Monday the 10th...
Offline damorgue
« Reply #25 on: Fri, 07 September 2012, 13:12:14 »
I am contemplating getting a few more. I see that I am way behind the others if only the listed ones and a couple of others ordered and we are already over 100 on each item.
Offline alaricljs
« Reply #26 on: Fri, 07 September 2012, 13:33:46 »
Put more stats in post 2 for the curious.  The odd totals are due to me already adding in a shipping to me approximation, then there's additional shipping out to you.
damorgue, I'd say you're in the average range whereas DanGWanG is at the top end ;)
Offline DanGWanG
  • Higher Standards
« Reply #27 on: Fri, 07 September 2012, 14:10:33 »
I just got too much **** to build >_>
Offline alaricljs
« Reply #28 on: Fri, 07 September 2012, 14:12:04 »
At least you're not blowing a few hundred on something you may or may not see in a year or so.
Offline alaricljs
« Reply #29 on: Mon, 10 September 2012, 16:35:39 »
Ok, had one drop out but we're still moving forward.  This closes midnight ET today!
Offline damorgue
Re: [GB - ENDING] Cherry MX PCB and plate mount stabilizer sets.
« Reply #30 on: Mon, 10 September 2012, 16:42:16 »
Should I get more or not?
that is the question
« Last Edit: Mon, 10 September 2012, 16:45:34 by damorgue »
Offline alaricljs
« Reply #31 on: Mon, 10 September 2012, 16:55:25 »
More now is cheaper, and you can always list them in the classifieds at a later date if you were wrong.  That said, it's a fairly cheap mistake if you can't get rid of them and don't go overboard with your order.  :)
Offline damorgue
« Reply #32 on: Mon, 10 September 2012, 17:00:47 »
Had to count how many I already got, got a few already. I think I'll be ok with the ones I have ordered from you. I should get some costar ones some day though.
Edit: Doesn't the Ergodox use stabilizers for the thumb keys? They aren't listed in the parts list.
« Last Edit: Mon, 10 September 2012, 17:02:51 by damorgue »
Offline alaricljs
« Reply #33 on: Mon, 10 September 2012, 17:10:26 »
Rendering says yes.
« Reply #34 on: Mon, 10 September 2012, 19:37:42 »
I know these are for the Cherry style stabilizers, but can I order 2 more 7-unit wires and you bend them for Costar for me?
Offline alaricljs
« Reply #35 on: Mon, 10 September 2012, 20:02:10 »
I don't have that size wire handy, it's also a whole lot more complicated of a bend job.  I hear litster has spares if you are willing to wait until all phantom orders are accounted for and verified by the recipient.  :)
Offline WRXChris
« Reply #36 on: Mon, 10 September 2012, 21:28:45 »
order sent!
« Reply #37 on: Mon, 10 September 2012, 22:19:54 »
Ok, thanks. I was just wondering. :D
Offline inlikeflynn
  • file not found
« Reply #38 on: Mon, 10 September 2012, 22:28:31 »
Just noticed this GB and put in a last minute order  ;D
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline alaricljs
Re: [CLOSED] Cherry MX PCB and plate mount stabilizer sets.
« Reply #39 on: Tue, 11 September 2012, 00:07:45 »
It's oooooooover.  Thanks :)   Get back to you soon with more info.  Thanks all 17 of you!
Offline alaricljs
Re: [ORDERED] Cherry MX PCB and plate mount stabilizer sets.
« Reply #40 on: Tue, 11 September 2012, 10:04:23 »
Just ordered the parts.
« Reply #41 on: Tue, 11 September 2012, 23:44:47 »
Rendering says yes.
Rats, I knew I was forgetting something.
Looks like I'll be taking apart my WYSE PCE 'board after all . Thanks anyway!
« Reply #42 on: Wed, 12 September 2012, 00:23:39 »
can i get enough for a kmac mini >.>
Offline sth
« Reply #43 on: Wed, 12 September 2012, 00:25:21 »
ygpm* demik
you gotta purdy mouth
« Last Edit: Wed, 12 September 2012, 00:27:14 by sth »
Offline alaricljs
« Reply #44 on: Wed, 12 September 2012, 12:43:53 »
Anyone that submitted orders late will have to wait until after everyone else gets dealt with.  I may have enough to cover what was requested.
« Reply #45 on: Wed, 12 September 2012, 21:17:37 »
Wow, WYSE PCE 'boards have an extra set of stabilizers (9 total), so I grabbed some spares from there. (that way I won't need any extras)
Cherry stabilizers don't fit in the phantom that well, but it looks like they'll work. I might be able to put some paper or plastic in there to make it work better.
I also found out that you can remove and replace individual switches that are plate mounted. It's not even that difficult.
Thanks for running this GB, alaricljs.
Offline damorgue
« Reply #46 on: Mon, 17 September 2012, 07:44:04 »
Is anyone interested in costar ones too? Shipping from WASD for just a couple is a *****.
« Reply #47 on: Mon, 17 September 2012, 10:22:25 »
I am. I want to see if they fit any better or worse than the cherry ones. I like variety.
Offline alaricljs
« Reply #48 on: Mon, 17 September 2012, 14:40:28 »
PCB mount stabs have arrived,  1/16" wire also arrived.  Waiting on the plate mounts and I'll start bending wires next week.  I got sent on a business trip to Utah again at the last minute.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: [ORDERED] Cherry MX PCB and plate mount stabilizer sets.
« Reply #49 on: Wed, 19 September 2012, 08:44:21 »
Woot.
-Enzo Ferrari
