Author Topic: Race constant LED on  (Read 5179 times)
Offline Cindori
    • My Blog
« on: Wed, 05 September 2012, 12:13:10 »
The suckiest thing about KBT Race is that LED resets on restart. This means you have to do Fn key mashing to re-enable the LEDs constantly.
Anyone think this might be modded to make the LED stay on always? By soldering somehow. I have experience with digital circuits but not so much with soldering.
If anyone has a hi res picture of the PCB that would be great.
« Last Edit: Wed, 05 September 2012, 12:15:01 by Cindori »
Offline domoaligato
Re: Race constant LED on
« Reply #1 on: Mon, 17 September 2012, 14:54:05 »
if you plug it into a powered usb hub it will stay on due to the powered usb hub using a dedicated power source.
make sure the usb hub has a separate ac adapter.
Offline sth
  • 2 girls 1 cuprubber
« Reply #2 on: Mon, 17 September 2012, 14:58:48 »
if it were a single key i would say you could just jump it but it requires an fn+key combination, so it's handled by the controller. not that it wouldn't be possible, just harder to do.
domoaligato -- that would work but it would be on ALL the time, and i think Cindori just wants it to come on automatically whenever the computer sends power.
« Reply #3 on: Mon, 17 September 2012, 20:28:05 »
The original Ducky Shine has this problem, but I don't reboot that often so it is not that much of a problem.
But if there is a simple hack that can be done, well ...
Offline 1391401
  • MX CLEAR
« Reply #4 on: Tue, 18 September 2012, 10:25:07 »
I forget if this happens on windows or linux, but when I had it connected to my Mac at work it would turn the LEDs off whenever the mac went to sleep too not just power off :\
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline Cindori
    • My Blog
« Reply #5 on: Tue, 18 September 2012, 13:51:45 »
well thats how sleep works. every led keyboard will behave the same.
its not the issue that it turns off, its the issue that I need to do hotkey dance with my fingers on every boot to get my preferred lightning mode.
here is hires pics of race boards:
Right click - Show image to get full sized.
That holtek controller is for the keyboard. I wonder what the other thing is. It looks a bit smeared, like someone wiped the text off it....
I´m not too comfortable with circuit boards, but I guess its likely to be that component responsible for the LEDS.
However, the thingies to the lower right also caught my eye. Are they D-elements? (state components) they are labeled Q1 Q2 Q3 Q4...
Offline sth
« Reply #6 on: Tue, 18 September 2012, 13:54:13 »
those are the DIP switches that swap keys around but i dont think that any of them keep the LEDs on.
Offline Cindori
    • My Blog
« Reply #7 on: Tue, 18 September 2012, 13:58:17 »
Ok Good
That rules those out!
We are making progress ;-)
Offline 1391401
  • MX CLEAR
« Reply #8 on: Wed, 19 September 2012, 20:11:43 »
I guess mac and PC is different - the mac goes to 'sleep' aka the screen turns off and all power to USB seems to be cut, whereas a PC goes to sleep and the screen just turns off.  Standby is a whole 'nother thing.  Would be cool though for the keyboard to have a memory and start back up at the same brightness/LED setting.
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Race constant LED on
« Reply #9 on: Thu, 20 September 2012, 01:18:26 »
sleep and standy have merged with win7
