Author Topic: Buying My First Mechanical Keyboard  (Read 2959 times)
Offline Origami_Duck
« on: Thu, 06 September 2012, 16:50:10 »
Hey everyone, so I'm taking the plunge and buying my first mechanical keyboard after years of using rubber domes. I think I have an idea of what I want but I'm not sure which keyboard best meets my criteria, so if you guys could advise that would be great.
I'm probably going with a Cherry MX board because I don't think I'm ready to pay for a Topre right off the bat. I've managed to track down Brown, Black, and Red switches to try out.
I think I like the feel of the browns the best, but I would really like to try blues (unfortunately I've looked literally everywhere I can think of in my area and there are none to be found.)
I seldom use the num-pad so I'll likely be looking for a TKL board. Finally, back lighting is not essential but would be a huge plus.
I was looking at a KBT Race, but apparently those are not manufactured at the moment (The LE version is being made right now, but I want a black board and would rather not pay extra for white key that I don't want).
So to sum up:
-Cherry Browns
-Black keys/case
-TKL
-Backlit (Optional, but preferred)
Any recommendations?
Offline swagpiratex
Re: Buying My First Mechanical Keyboard
« Reply #1 on: Thu, 06 September 2012, 16:53:56 »
Wait for the Ducky Shine II to come out. I think Reddit is gonna do a massdrop on them. They should be out sometime this month.
If you can't wait, then try looking at a Leopold at Elitekeyboards.com
« Reply #2 on: Thu, 06 September 2012, 17:10:54 »
Welcome to Geekhack!
Ducky Shine II is not TLK :(
AFAIK there are not too many TKL backlit keyboards, but I welcome corrections.  At least when I started looking only a few months ago I could not find any!
Offline FoxWolf1
  • 154
« Reply #3 on: Thu, 06 September 2012, 17:44:45 »
Just a list meeting your criteria, with no comment on how good/bad any of them are:
-Ducky Year of the Dragon (link)
-Keycool 87 Backlit (link)
-KBT "Oni" Backlit (sorry, you'll have to find your own link for this one)
-If you're willing to consider smaller than the standard TKL size, you can add in the Noppoo Mini, Keycool 84, Deck 82, some other KBT/KBC boards, and probably more.
Also, if you look around a little, I'm sure you can still get a black KBT race.
Happy researching!
« Reply #4 on: Thu, 06 September 2012, 22:32:15 »
Thanks for the suggestions everyone.
Ducky Shine II is perfect, except that it is a full keyboard not a tkl. =( Thanks for the suggestion though
Thank You! Yeah... I'm having a hard time finding anything that fits my criteria.
Happy researching!
Thank you for the suggestions. I forgot to mention... I'd be looking for either red or white back lighting... (I know, I know... It's just I can't justify paying the extra $30-$70 markup for back lighting if it is a color I don't want.)
The closest thing I can find is this Key Cool 87: link
How are they in regards to build quality?
Also if I were going to go with a non-backlit choice, what is the best quality for under $140 for a TKL? My research tells me Leopold or CM Storm Quickfire (Hate the key-set though) what is your opinion, are there other options I should consider?
Also, in regard to Cherry Blue switches... I really like the tactile feel of the Browns, but they are ALMOST too loud for me. That said, if I were to buy a board with blues and then put some o-rings on would that be about the same sound level?
Thanks in advance.
Offline mmmty
  • bang! bang!
« Reply #5 on: Thu, 06 September 2012, 22:55:24 »
Blue switches are overrated. They're as loud as brown switches but have that annoying clicky sounds.
Actually I like the clicky sounds but for some reasons my typing sucks when I type on keyboards with blues.  :'(
Keyboardless
« Reply #6 on: Thu, 06 September 2012, 23:50:22 »
You can get a CMstorm Quick fire rapid and a PBT keycap set for that price. I recommend it as an excellent combination.
« Reply #7 on: Fri, 07 September 2012, 02:08:44 »
Thanks for the suggestion. Would you recommend that setup over a leopold (which is about the same price as those two)?
« Reply #8 on: Fri, 07 September 2012, 09:57:50 »
The biggest issue with leopold (in my mind) Is the spacebar incompatibility. Spacebars for filco, cherry, CMstorm, ducky, etc. won't work with it.
You can, however, get leopolds now with PBT keycaps, and spacebar. If you're not big on changing the keycaps, it's probably the cheapest option to get PBT Tenkeyless.
Offline hq1ify
  • daddy cool
    • mtod.org
« Reply #9 on: Fri, 07 September 2012, 12:52:19 »
Just make sure you won't get ABS keycaps. The difference between these and thick PBTs is *huge*
HHKB Pro 2 / Poker Brown
« Reply #10 on: Fri, 07 September 2012, 21:57:30 »
Thanks. Is there a way to tell if the version I'm ordering has pbc caps? (Leopold)
Also, any other opinions on getting blue switches with o rings instead of browns?
« Reply #11 on: Sat, 08 September 2012, 00:47:29 »
Well, I saw the discount coupon for CM and I jumped on it. Thanks for the help guys!
Just ordered a CM Storm Rapid with Brown Switches. Thinking I'll probably order some o-rings from WASD to go with it though, the one I tried in store was just at the brink of being too loud for me, plus I like tactility.
So excited.  :D
