Author Topic: How are keycaps made?  (Read 8110 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« on: Tue, 11 September 2012, 00:30:37 »
I've seen some who are hand made but what other methods are there? are they done using a 3d printer or a different kind of machinery?
Offline Lu_e
Re: How are keycaps made?
« Reply #1 on: Tue, 11 September 2012, 01:46:55 »
Injection molding?
idk if keycaps can be done like this but its interesting anyway;
Just say NO to ABS keycaps
« Reply #2 on: Tue, 11 September 2012, 23:28:31 »
3-D printing is really just a method for rapid prototyping: you can make arbitrary shapes quickly and cheaply, but there are much faster and cheaper options for large runs. (Also, I prefer SLS (Selective Laser Sintering) to 3D printing, but I digress.) Injection moulding is probably the most prevalent. After the blank key is moulded, it's either moulded again (for doubleshots: It stands for double shot injection moulding) or a printed pad is affixed to the top (the keycap is usually clearcoated). This is by far the most common for cheaper keyboards. Other methods for finishing the legends is to etch or engrave them with a laser, or use "dye sublimation" on PBT (Dyesub does not work on ABS, as far as I know).
DIY keycaps are primarily made from either moulding (Like injection moulding, but on a much smaller scale), or by building up layers of another material (for colour or shape) and finishing it off with a protective clear coat.
Offline Calade
« Reply #3 on: Wed, 12 September 2012, 14:20:15 »
Would be interesting to know the costs of actually starting a keycap production line. Does anyone know how much an injection moulding machine costs? And one would probably have to make all the moulds by themselves too? The beast in that video looks like something in the range of hundreds of thousands of dollars, but there are probably much smaller solutions as well.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Wed, 12 September 2012, 14:23:34 »
There are hobby sized injection molding machines that could probably handle ~4 1x caps that cost a few thousand dollars.  But that's single injection.  Most people are thinking of at least dual injection (double shot) and I've never heard of a small machine that does that.
Filco w/ Imsto thick PBT
Offline oluf
  • formerly olaph
« Reply #5 on: Wed, 12 September 2012, 14:38:59 »
Signature Plastics has some info about "insert molding" here, http://keycapsdirect.com/faq.php
...And they list the equipment they use here, http://keycapsdirect.com/facility.php
« Reply #6 on: Wed, 12 September 2012, 19:03:28 »
I remember Dad bought one for ~$55,000 when he founded a company once, but I imagine if you could find one used, or get one of those smaller ~$5k ones, it wight be worthwhile. Remember: Moulds can be pretty expensive, too.
SP has a lot of nice machines, but you could probably get started with a decent workable setup with no more than 100-200k invested, depending on how long you want to look out for good deals.
