Author Topic: Adding LED to keyboard  (Read 4442 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« on: Tue, 11 September 2012, 10:28:21 »
Does anybody have a guide on how to ADD LEDs to a Filco? i have an acrylic transparent case and i want to add LEDs to it in the background.
Cheers,
Offline Icarium
  • I AM A MONKEY!
Re: Adding LED to keyboard
« Reply #1 on: Tue, 11 September 2012, 10:44:19 »
Don't know about the specific case of a Filco but it's usually next to impossible.
Edit: Because there usually isn't enough power to light them up and no suitable traces either.
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Tue, 11 September 2012, 10:44:41 »
Probably the easiest way would be to drill into the inside edges of the acrylic so led can go in. Then tie it to the +5v line from usb with the approritate resistor. It will give a cool diffused glow effect.
Adding like backlight will be quite a lot more work, and the pcb is not set up for it so quite a lot of wiring would be under the plate that way. You would have to desolder everything, insert the led into switch, bend the legs so they do not interfere and create your own wire matrix  for the led, and so on. It's possible just a lot of effort.
Offline Mugen
« Reply #3 on: Tue, 11 September 2012, 12:59:59 »
How do i know which wire is the +5v?
Offline Icarium
  • I AM A MONKEY!
« Reply #4 on: Tue, 11 September 2012, 13:02:19 »
Type "usb connector pinout" in a your favorite search engine.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Tue, 11 September 2012, 14:01:09 »
Lick them.
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #6 on: Tue, 11 September 2012, 16:33:07 »
