Author Topic: Zinc Arrow keys  (Read 3546 times)
  • Live long and prosper
Zinc Arrow keys
« on: Wed, 12 September 2012, 14:48:48 »
Ok, so I have a set of feng's zinc arrow keys on my Ducky DK1087.  They fit rather tightly on the key stem, and I was wondering if there is a safe way to remove them without pulling out the stem? I want to be able to remove them when my DDR arrow keys arrive.
Any ideas on how I can do this without damaging the key switches?
tp thread is tp thread
Offline longweight
  • philanthropist
Re: Zinc Arrow keys
« Reply #1 on: Wed, 12 September 2012, 15:01:41 »
Carefully! I can't think of a way to make sure that the stem doesn't come out, this is why I never fitted the zinc caps to my Filco.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Zinc Arrow keys
« Reply #2 on: Wed, 12 September 2012, 15:12:55 »
Easy, just desolder the switch! LOL.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: Zinc Arrow keys
« Reply #3 on: Wed, 12 September 2012, 15:14:29 »
I'd take a combination of what the above 2 posters said...
- Carefully try to pull it out...
- If that fails, get ready to desolder =)
Re: Zinc Arrow keys
« Reply #4 on: Wed, 12 September 2012, 15:15:46 »
Ok, thanks for the suggestions... I'll try CAREFULLY removing them when I get home. Hopefully I don't break any switches in the process...
Re: Zinc Arrow keys
« Reply #5 on: Wed, 12 September 2012, 19:05:34 »
I would see about cutting some thick flexible material, and putting it under the keycap. It'd provide something to pull against, and may help the stem stay in place.
I thought about fabricating something when I pulled off my anodyzed aluminium keycaps, but I was able to manage.
Offline raisinbun
Re: Zinc Arrow keys
« Reply #6 on: Wed, 12 September 2012, 22:53:21 »
I sanded the inside of the stem of my metal keycaps before mounting them...  :rolleyes:
Re: Zinc Arrow keys
« Reply #7 on: Fri, 14 September 2012, 06:41:31 »
Well luckily I was able to remove the caps without pulling out any of the stems, so it's all good now. Thanks guys for the help!
