Author Topic: Any Clue What This Is?  (Read 4673 times)
Offline f/64
« on: Wed, 12 September 2012, 20:52:39 »
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=190724675261#ht_500wt_1414
I hadn't seen it before and can't find anything; I even crawled through old Radio Shack catalogs lol.
Offline f/64
Re: Any Clue What This Is?
« Reply #1 on: Wed, 12 September 2012, 20:58:30 »
Looks like a keyboard.
(sorry I had to)
No problem, I expected it.
Offline SmallFry
« Reply #2 on: Wed, 12 September 2012, 21:02:05 »
Did you win it? That looks cool! almost like a vintage poker of sorts.
Offline f/64
« Reply #3 on: Wed, 12 September 2012, 21:06:26 »
Yeah, for $20, I figured what the hell. I think one/some of the old TRS models had cherry compatible caps. If not, then it's old enough to be Mitsumi ALPS.... I think...
« Reply #4 on: Wed, 12 September 2012, 21:43:22 »
I think it is meant to replace the built-in keyboard on a TRS-80. Kinda like how you can buy replacement keyboards for laptops now.
Offline f/64
« Reply #5 on: Wed, 12 September 2012, 21:45:19 »
That's what I originally thought as well, but I couldn't find one that matched the metal tabs at the top on the auction board.
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #6 on: Thu, 13 September 2012, 00:50:23 »
Recognized it the moment I saw the photo; It belongs to an Atari 1200XL.
http://www.atarimuseum.com/computers/8BITS/1200xl/1200xl.html
Weird, huh?
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
« Reply #7 on: Thu, 13 September 2012, 08:29:22 »
1982 so probably not domes.
Yep, that looks exactly like it, Burz. You have a good eye. Did you own one or something?
Offline Burz
« Reply #8 on: Thu, 13 September 2012, 09:02:23 »
I wanted one when I was small; Now I have one.
Offline f/64
« Reply #9 on: Thu, 13 September 2012, 12:43:56 »
Weird, huh?
You da man. Any idea what type of switches it uses? I saw it had a Mitsumi sticker on the pcb.
Offline Burz
« Reply #10 on: Thu, 13 September 2012, 17:36:01 »
I remember them as feeling linear, thats all. Its been a while since I packed it away in the basement.
Offline sth
  • 2 girls 1 cuprubber
« Reply #11 on: Thu, 13 September 2012, 17:37:12 »
I have the numpad from that machine, same caps. i love the feel of the switches... and yes they are linear.
Offline f/64
« Reply #12 on: Thu, 13 September 2012, 17:46:40 »
If I can't find anything to do with it, maybe I can just resell it. I read earlier that the 1200xl had a great keyboad, but it had a tendency to die.
Offline f/64
« Reply #13 on: Thu, 13 September 2012, 17:56:52 »
Any idea if it can be converted to work on a new PC?
Edit:
From what I understand, this could work. Not for me at $170 though.
http://www.hagstromelectronics.com/products/ke_usb108.html
« Last Edit: Thu, 13 September 2012, 18:30:05 by f/64 »
« Reply #14 on: Sat, 15 September 2012, 00:40:50 »
The easiest way might be to just forgo the old controller (Ribbon cable?) and wire the switches to a teensy directly.
Another option is to try and convert that old protocol. I know some people like Haata are good at that sort of thing.
