Author Topic: Cutting a 11800, searching for a pic  (Read 2886 times)
Offline domin8r
« on: Thu, 13 September 2012, 04:24:19 »
Hi,
I've gathered all the stuff I need for a mod to a 11800. Wanna cut off the numeric and trackball.
There was a picture posted by elbowglue that showed where to cut the board so you wouldn't need to solder anything.
I had saved the image but I've lost it through a HD failure. And it seems it's also not in the thread anymore (due to the upgrade I suppose).
Contacted elbowglue himself but he seems inactive.
Does anyone have this image? My saw is ready to go! :D
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
Offline modulor
Re: Cutting a 11800, searching for a pic
« Reply #1 on: Thu, 13 September 2012, 08:47:45 »
http://deskthority.net/marketplace-f11/spacesaver-mod-compaq-cherry-mx-11800-to-tenkeyless-85k-t2649.html
Kint over at DT was trying to sell his 'ssk' modded 11800 a little bit ago, but he has some pictures in the listing.  I'm checking to see if his worklog is still up over there, but you could also message him about advice.  I've been contemplating doing this to my 11900 just as a fun project.  His results were pretty good, too :)
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline domin8r
« Reply #2 on: Thu, 13 September 2012, 08:50:38 »
Ah, I've actually have had contact with Kint a while ago ( I was appalled noone was buying his tkl 11800).. Good call to ask him about it! Thanx for the tip!
Ducky 1087XM
Black Dell AT101W
« Reply #3 on: Thu, 13 September 2012, 14:12:58 »
You just cut between the 741 and 852 columns of the numeric keypad. Kint cut some more than that, apparently.
Offline domin8r
« Reply #4 on: Fri, 14 September 2012, 04:19:07 »
Yeah I remember cutting next to the first column of the numpad, but that it wasn't a straight line down from day. Had a bit of a bend to it halfway down the pcb.
Ducky 1087XM
Black Dell AT101W
