Author Topic: siemens nixdorf identification  (Read 7204 times)
Offline Vukota
« on: Fri, 14 September 2012, 08:09:53 »
Does somebody know anythinf about this keyboard? Rubber rome, mechanical?
Offline Icarium
  • I AM A MONKEY!
Re: siemens nixdorf identification
« Reply #1 on: Fri, 14 September 2012, 08:25:48 »
No idea, but I'd buy it to find out. :)
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 14 September 2012, 08:30:07 »
Looks like spherical caps too... intriguing.
Filco w/ Imsto thick PBT
Offline Wildcard
  • When caffeine isn't enough
« Reply #3 on: Fri, 14 September 2012, 10:32:51 »
Pull a cap off and show a picture of the bottom of the cap and key stem.
Edit: good find
« Last Edit: Sat, 15 September 2012, 01:23:02 by RiffRaff »
Offline Vukota
« Reply #4 on: Fri, 14 September 2012, 12:23:04 »
I don't have it, but i saw one :)
it looks like this one, but this one is nixdorf http://keyboardporn.com/mx-switch/g80-0801-nixdorf-softclick/
and this one http://keyboardporn.com/mx-switch/nixdorf-softkeys/
what do you think, are the cherry black on the siemens-nixdorf?
« Last Edit: Fri, 14 September 2012, 12:24:57 by Vukota »
« Reply #5 on: Sat, 15 September 2012, 00:45:53 »
You should get it, just for the chance at those clear cherry switch upper housings.
Offline Wildcard
« Reply #6 on: Sat, 15 September 2012, 01:24:22 »
That is pretty much the same board and a great find. If you decide the switches aren't your taste could you possibly proxy it for me?
« Last Edit: Sat, 15 September 2012, 01:36:52 by RiffRaff »
Offline Vukota
« Reply #7 on: Sun, 16 September 2012, 13:24:26 »
It's cherry black clear upper housing :)
Offline damorgue
    • Personal portfolio
« Reply #8 on: Sun, 16 September 2012, 13:40:00 »
I wonder if those would disperse light better under the key cap and diffuse the spot effect you sometimes get with LEDs. I will probably get lynched for even suggesting that you remove them from the keyboard.
« Reply #9 on: Mon, 17 September 2012, 12:33:52 »
You'd have to get a really wide viewing angle LED's for it to make a difference at all. Probably something like pi/4 steradians or better.
This is the best switch housing for use with clear keycaps, IMO.
Offline Vukota
« Reply #10 on: Wed, 19 September 2012, 05:37:39 »
this keyboard has din-6 connector (not mini din-6 (ps2)). Is is PC compatible? (i don't have adapter so i can not test it)
« Reply #11 on: Wed, 19 September 2012, 09:58:30 »
If it's a 180-degree Din6 connector, an AT connector, then it should work with a passive adapter to PS2. My SIIG minitouch has that one, and I'm using it with an adapter to PS2 (then another one to USB)
Offline Vukota
« Reply #12 on: Wed, 19 September 2012, 15:43:47 »
Mine looks like this. Yours?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #13 on: Wed, 19 September 2012, 15:54:58 »
Sure it's 6 pins not 5? If it is 5 pins, then it is hopefully AT and not XT only, then you just need one of these:
or do what I usually do and replace the original cable with a PS/2 cable so I don't have to use adapter anymore.
If it is 6 pins, then it is probably something non standard and I would just part it out unless you want to keep it for collection purpose only.
« Last Edit: Wed, 19 September 2012, 15:59:22 by lysol »
Offline Vukota
« Reply #14 on: Thu, 20 September 2012, 03:55:05 »
It's 6 pin. I have a 5 pin keyboard, and adapter to ps2, so i know it is not a din-5, it's din-6 (not mini din-6)
p.s. I think it't keyboard from Nixdorf Targon, DEC compatible terminal. Is there possibillitu that this keyboard it AT? Or is it XT?
pss amstrad keyboards have DIN-6 and they are XT
« Last Edit: Thu, 20 September 2012, 13:05:19 by Vukota »
« Reply #15 on: Fri, 21 September 2012, 09:08:15 »
Not sure. If it is XT then you could do something with one of Soarer's converters to use it on modern computer. If it's AT and using a different plug, then just replace the cable... either way I think you should open it and have a look. Hopefully the cable connector or solder pads are labeled on the pcb and we can know for sure.
« Last Edit: Fri, 21 September 2012, 09:10:56 by lysol »
Offline sphinx
« Reply #16 on: Thu, 09 April 2015, 08:28:43 »
hello,
i've recently aquired a nixdorf softkeys keyboard. it seems in good condition and i wanted to get it working.. did you manage do make any progress?
thanks
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #17 on: Thu, 09 April 2015, 09:02:35 »
