Author Topic: Number pad - mechanical, low cost?  (Read 4978 times)
Offline c64
« on: Fri, 14 September 2012, 13:35:18 »
I'm looking for a number pad since I use my left hand to type numbers.  What is the cheapest number pad I can buy (wired) that has mechanical switches?
Offline hoggy
  • * Moderator
Re: Number pad - mechanical, low cost?
« Reply #1 on: Fri, 14 September 2012, 13:38:46 »
Look for a kinesis/goldtouch (same thing) numpad.  Cherry browns from memory.  Good quality.
Stupid money if you buy them new.  You could get a nasty rubber dome thing to tide you over while you hunt...
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Fri, 14 September 2012, 14:07:37 »
Goldtouch numpads with brown switches show up regularly on ebay for $20-$30.
Offline sth
  • 2 girls 1 cuprubber
« Reply #3 on: Fri, 14 September 2012, 14:17:05 »
one thing to keep in mind with the goldtouch (filco numpads too) is that they come with 0 and 00 keys instead of a 2x 0 key. if you care about keycaps you're gonna want to replace the keycaps on the goldtouch right away, and tracking down the right 0 and 00 keys is not as easy as finding a 2x 0 key.
Tsangan's CCnG kit came with the right sizes, and there are black cherry doubleshots that came with those too.
Offline Rafen
« Reply #4 on: Fri, 14 September 2012, 20:59:26 »
Not to thread jack but I am also looking for one of these. I don't use the number pad all the time because I only need it mostly for entering IP addresses at work and trouble shooting computers and would love to have a mechanical one.
Offline Gerk
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
Offline c64
« Reply #6 on: Mon, 17 September 2012, 16:38:40 »
I keep seeing Adesso ones all over the place for reasonable money.
http://www.amazon.com/ADESSO-AKP-220B-Adesso-Mechanical-Numeric/dp/B0038KN3YY/ref=sr_1_3?ie=UTF8&qid=1347717055&sr=8-3&keywords=adesso+number+pad
That one looks good to me and in the price range.  Any negatives about it?
Offline Gerk
« Reply #7 on: Mon, 17 September 2012, 16:54:12 »
Dunno ... have never used it, just see it listed all over and the price looked right.  Been thinking about one myself but haven't done it yet.
Offline sth
« Reply #8 on: Mon, 17 September 2012, 17:47:15 »
I have a goldtouch with the original keys, never use it. i'll sell it for $25+ shipping CONUS... shoot me a PM if you're interested. It's been a while since I've used it so I have to plug it in and make sure it works before I sell it, but I never had any problems with it.
I steel-wooled the logo off so there is a slightly shiny spot but it's not really that noticeable unless you're pointing a bright lamp directly at it.
