Author Topic: another HHKB for travel or something else? (also case ideas?)  (Read 2967 times)
Offline blackrim
« on: Sun, 16 September 2012, 20:57:26 »
I have had filcos (blues and reds) and an older das keyboard (with browns) and just got my HHKB pro and gotta say that I am now a convert. Love the thing. I have it for use coding on my workstation at work, but I would love to take something on the road with the laptop. The questions are:
  • Am I missing a great small mechanical keyboard that would be good for travel or should I just get another HHKB?
  • Are there good cases for whatever is suggested (or are the two at elitekeyboards the best)
Realforce TKL 45g | HHKB (white and black) | Filco TKL blues | Das Ultimate browns | Kinesis Advantage
Offline Dajm
Re: another HHKB for travel or something else? (also case ideas?)
« Reply #1 on: Sun, 16 September 2012, 23:58:15 »
I think it really depends on your budget. Potential candidates that come to mind are the KBT Pure or Race, for instance. But these are in the price range of 100-120 $, not comparable at all to the price of a HHKB pro. The quality you get is also in a different league, from what I hear (haven't had a HHKB personally, but I can imagine that there's a big difference).
If you don't mind paying the price for another HHKB, then go for it. But if you want to try something else to see if a less expensive board will do the trick for you as well, you could try a Pure, for instance, and resell it if you don't like it.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Mon, 17 September 2012, 00:42:18 »
You could make a dox if you can get you hands on a poker case.
Offline longweight
  • philanthropist
« Reply #3 on: Mon, 17 September 2012, 01:33:32 »
I would get another HHKB, it drives me nuts switching between the HHKB, TKL and Poker layouts! I will be getting another HHKB to replace my Poker this week I think.
Re: Re: another HHKB for travel or something else? (also case ideas?)
« Reply #4 on: Mon, 17 September 2012, 01:42:27 »
I do like my HHKB but i think i have improved on it with my dox/phantom layout.
Offline blackrim
« Reply #5 on: Mon, 17 September 2012, 07:50:34 »
i thought layout switching might be annoying. i am newer here so wasn't familiar with the dox. looks interesting
Offline reaper
« Reply #6 on: Mon, 17 September 2012, 08:44:08 »
Din Eli
Offline blackrim
« Reply #7 on: Mon, 17 September 2012, 09:54:54 »
like the case idea, and you obviously don't agree with the bad reviews?
Offline hcry4
  • HHKB Hoarder
« Reply #8 on: Mon, 17 September 2012, 10:26:19 »
I would stick with HHKB. Both cases are fine, but you can carry a bit more stuff with the tenkeyless size even though the open part with no zipper kind of sucks.
Offline blackrim
« Reply #9 on: Mon, 17 September 2012, 10:45:54 »
do you also use a keyboard roof in the case or the case is enough?
Offline hcry4
  • HHKB Hoarder
« Reply #10 on: Mon, 17 September 2012, 10:54:55 »
No roof in the case. Never even considered it. The HHKB case is snug. It will slide around a bit in the tenkeyless size case, so I would think that putting a roof in there is a bad idea.
Offline blackrim
« Reply #11 on: Mon, 17 September 2012, 12:52:45 »
Sounds good. Thanks for the advice. I think I am just going to go with HHKB and the elitekeyboard case. Now I just have to decide if the white looks mac or retro or stick with the grey
Offline longweight
  • philanthropist
« Reply #12 on: Mon, 17 September 2012, 13:00:23 »
Always white!
Offline baylanger
« Reply #13 on: Mon, 17 September 2012, 19:00:39 »
White or Grey - I have the same question in mind and this is my first HHKB.  If at night you keep your light dimmed, maybe white isn't a good idea -- but if you're already used to the key layout, that might not worry you.
Offline blackrim
« Reply #14 on: Tue, 18 September 2012, 12:20:50 »
For anyone that cares, I settled on another HHKB (going white cause I have gray) and I am just getting the EK soft case
Offline longweight
  • philanthropist
« Reply #15 on: Tue, 18 September 2012, 12:33:24 »
Good choice!
