Author Topic: Northgate Omnikey Ultra-T manual reprogramming  (Read 2172 times)
Offline Emile
« on: Mon, 17 September 2012, 20:46:44 »
Can the Northgate Omnikey Ultra-T be manually programmed?
I have read about a method that involves pressing the right ctrl key four times, then  the ! key (shift 1), then the r key.
It  does nothing on my Ultra-T. Is the Ultra-T the same as the Ultra?
I really would like to remap the key between left ctrl and left alt to be the "Windows" key. without using the operating system to do the
remap.
When I do the key combo mojo suggested here http://www.lemis.com/grog/HOWTO/Avant-Stellar.php
nothing happens.
Are there any Ultra-T users here that have successfully re-mapped keys manually?
Thanks,
Emile
