Author Topic: DIY Photography Lightbox  (Read 2691 times)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« on: Tue, 18 September 2012, 02:27:50 »
I spent the evening watching Aliens and making a simple lightbox downstairs (Mrs Hashbaz refused to watch the movie with me).
Instructions here: http://strobist.blogspot.com/2006/07/how-to-diy-10-macro-photo-studio.html
Total cost to me was < $5 (for white posterboard and tissue paper), total build time < 30 minutes.  Easy peasy lemon squeezy.
I'm not totally happy with my first round of images, shown below.  I experimented with different exposure, ISO, and white balance settings, as well as some tweaking in Gimp later on.
« Last Edit: Tue, 18 September 2012, 02:36:59 by hashbaz »
Offline jpm804
  • KeyCap Assasin
Re: DIY Photography Lightbox
« Reply #1 on: Tue, 18 September 2012, 02:31:09 »
Nice lightbox...
Try using using those natural light bulbs which has more white effect to it versus normal light bulbs which tend to make things more yellow or using something like lightroom to fix the white balance..
I am by no means a photo expert but some simple tips I use.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline jeroplane
« Reply #2 on: Tue, 18 September 2012, 05:04:48 »
Very nice. I once made something similar under my table (which is white) after reading that exact tutorial, but have since got a real lighting setup haha.
To add to what jpm said, the key thing is making sure the light temperature is consistent all round. Make sure no other lights are on, and don't use your camera flash. Also, I can't tell from your photo, but the translucent cover of the left lamp may affect the temperature too.
Also, always use a tripod (or equivalent stabilising object).
You should be able to deal with the white balance by tweaking in-camera, but Adobe Lightroom makes things a lot easier if you can get it.
My signature hasn't changed since 2012. I should really update it.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #3 on: Tue, 18 September 2012, 05:13:36 »
thanks for sharing! (looking for a big enough cardboard box, there must be one somewhere)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #4 on: Tue, 18 September 2012, 06:59:17 »
shoot raw and use a neutral card to get the temp of your light
alternatively, you can pretty neutral backdrops at the art store and just take the temp using those.
Offline hashbaz
  • Grand Ancient One
« Reply #5 on: Tue, 18 September 2012, 11:40:00 »
Thanks for the tips guys.  Will be playing around with this some more and posting the results!
Offline SmallFry
« Reply #6 on: Tue, 18 September 2012, 13:35:50 »
Might need yourself a good flash too. I'm not sure on how photography works, my boss did all of my pictures. :)
  • Live long and prosper
« Reply #7 on: Tue, 18 September 2012, 13:37:39 »
Nice and simple.  I might have to make myself one of these...
tp thread is tp thread
