Author Topic: Fan controller  (Read 2006 times)
Offline ra7c7er
Fan controller
« on: Wed, 19 September 2012, 10:28:58 »
I've been looking at fan controllers for over a month now and I don't seem to be getting anywhere. I've looked all over the net (newegg, tigerdirect, etc) and can't find anything that gets solid good reviews. Are fan controllers that hit or miss?
I need a fan controller for 5 fans. I don't need variable speed just on and off but I don't really like the switch type ones I see everywhere because they only run at 7v max. I think I am leaning towards the Scythe controllers but I don't need all the features it has. It does come with all the extensions I would need that is a plus.
Anyone have any suggestions? Thanks.
Offline Appeac
Re: Fan controller
« Reply #1 on: Wed, 19 September 2012, 11:17:54 »
I had great experiences with a scythe Kaze Q, which is a 3.5" 4 slot variable controller. I can't speak for any 5.5" bay controllers, but the technology isn't really that complicated. You could even DIY it with some fan splitters, switches, and some soldering ability.
FC660C
122 Terminal M w/ Soarer board
Offline Will@Drop
  • MD Co-Founder
    • Massdrop
Re: Fan controller
« Reply #2 on: Wed, 26 September 2012, 21:28:06 »
It might be worth considering using a case with an integrated fan controller if the scythe models dont tickle your fancy. The NZXT Phantom has a five fan controller built in I think.
Offline TheProfosist
  • Custom Layouts Only!
Re: Fan controller
« Reply #3 on: Wed, 26 September 2012, 23:17:21 »
Get the nzxt mix or mesh both and great and can suport high end fans i believe fractle is coming out with a 6 fan one based on the same design as well. Most other ones can only do one amp total which if you buy good fans is only good for  3-4 fans max if not less.
« Last Edit: Wed, 26 September 2012, 23:21:07 by TheProfosist »
