Author Topic: Is Slimblade suitable for small hands?  (Read 3354 times)
Offline chief
« on: Sun, 23 September 2012, 13:51:57 »
Does anyone kniw if the kensington slimblade suitable for those with small hands.  I was tempted in getting the CST trackball but reckon the scrolling will be too much of a pain with my small hands.
I was wondering if anyone with small hands has any issues with the slimblade or if they don't whether their partners have issues.
Thanks
Offline oneproduct
  • @Ubisoft
Re: Is Slimblade suitable for small hands?
« Reply #1 on: Mon, 24 September 2012, 00:59:05 »
I've got pretty small hands and didn't like the CST because of the scroll bar's position, which is too far to reach relative to where the ball itself is. I quite enjoy the slimblade though, and would recommend it. You can see a little comparison here: http://www.youtube.com/watch?feature=player_detailpage&v=b6BhNqCgG-E#t=342s
Layout: Colemak
Offline chief
« Reply #2 on: Mon, 24 September 2012, 08:58:30 »
Thank you, I bit the bullet and ordered it.
