Author Topic: Post your Korean Keyboard ^_^  (Read 14004784 times)
0 Members and 21 Guests are viewing this topic.
Offline esoomenona
  • Gnillort?
« Reply #3150 on: Thu, 16 October 2014, 11:42:14 »
« Last Edit: Fri, 04 September 2015, 11:12:49 by esoomenona »
Re: Post your Korean Keyboard ^_^
« Reply #3151 on: Thu, 16 October 2014, 11:46:47 »
Are these holes not for PCB mounted stabs?
Yes, they are. 356/456/360 all use PCB mount stabilisers, but that doesn't mean they're PCB mount boards.
Here, look. Photos of my 360. The PCB and mounting is exactly the same on the 356.2. There's holes for PCB stabilisers but no holes to screw it down to a case. So, it needs to be plate mounted. :
Plate is screwed to the top piece. Top piece is then attached to the bottom piece.
Offline esoomenona
  • Gnillort?
« Reply #3152 on: Thu, 16 October 2014, 11:54:22 »
« Last Edit: Fri, 04 September 2015, 11:12:18 by esoomenona »
« Reply #3153 on: Thu, 16 October 2014, 11:58:48 »
So the plate is only required to keep the PCB in place, not required for holding anything to the PCB. I think there is solely a misunderstanding of what plate mount means to you .
Correct. The plate is what positions the PCB. There's no way to screw the PCB down like on a poker.
My definition for plate mount has always been : The plate is necessary. Remove it and you don't have a functioning keyboard.
I understood that to be the general definition too. I have never heard another.
For example, a poker with a custom metal plate is still PCB mount, since it would be fine without the plate. A Filco or a 356.2 on the other hand would be plate mount, since they rely on the plate.
Offline esoomenona
  • Gnillort?
« Reply #3154 on: Thu, 16 October 2014, 12:05:07 »
« Last Edit: Fri, 04 September 2015, 11:12:05 by esoomenona »
« Reply #3155 on: Thu, 16 October 2014, 12:11:21 »
That makes sense. My consideration has always been per component. The PCB maintains holes for both PCB mount switches and PCB mounted stabs, thus the plate is hardly necessary, except for its need to hold the PCB in place. Thus, I considered the components all PCB mounted, but the board itself still requires some sort of plate.
Ah right.. I get you now. Makes sense.
I think every Korean custom is like this actually. Holes for PCB mount switches & stabilisers. Some of them do support 'true' PCB mounting like the KMAC2, Koala?, and some others I can't think of off the top of my head. The 356/456/360 series are definitely all 'plate required' boards though, and they use the partial poly plates to try and replicate the feel of PCB mount.
Offline YongJK
« Reply #3156 on: Thu, 16 October 2014, 12:12:12 »
Korean ver. gmk dolch
Keyboard: PLU ML87 Mx Blue
Offline archer
« Reply #3157 on: Thu, 16 October 2014, 18:18:13 »
New GMK Dolch keycaps arrived yesterday compliments of Ivan's GB.. I wanted some text legends to match the enter key, so I mixed in some GMK Dolch from Originative. Installed on a GON NerD87.
I like the end result!  :thumb:
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #3158 on: Thu, 16 October 2014, 22:09:35 »
I think text on the modifiers looks much better  :thumb:
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #3159 on: Thu, 16 October 2014, 22:11:25 »
looks really good archer, that blue enter compliments the dolchie well.
Offline pmh1410
« Reply #3160 on: Thu, 16 October 2014, 22:12:41 »
360C + 356mini
Offline Michael
  • Formerly Bro Caps
« Reply #3161 on: Thu, 16 October 2014, 22:44:34 »
360C + 356mini + fake garbage clacks
ftfy
Offline pmh1410
« Reply #3162 on: Thu, 16 October 2014, 23:07:22 »
Bro, They are all fake ?
Offline pmh1410
« Reply #3163 on: Thu, 16 October 2014, 23:13:38 »
Hi YJK, your Desko set from Imsto store or OG Desko set ? i'm curiour about it :)
Offline Michael
  • Formerly Bro Caps
« Reply #3164 on: Thu, 16 October 2014, 23:49:02 »
Most likely, yes. Considering your support for counterfeiters.
Offline pmh1410
« Reply #3165 on: Fri, 17 October 2014, 00:24:04 »
k3kc is collector of CC and BB a longtime, he had them and he wasn't need my support anything.
I have enough keycaps and keyboards so i don't know and don't care anymore about BB, K3KC and history behind you and him. Don't bother me again, pls ;)
Offline Michael
  • Formerly Bro Caps
« Reply #3166 on: Fri, 17 October 2014, 00:37:29 »
k3kc is collector counterfeiter of CC and BB a longtime, he had them and he wasn't need my support anything, but I fully endorse him on my Vietnamese forum.
ftfy
and as long as you still post here, I will 'bother' you.
Offline pmh1410
« Reply #3167 on: Fri, 17 October 2014, 04:05:39 »
ftfy
Okie, no pbls sir.
But i think that you make BBs and sell at 35-50$$ expensive price for make a BIG PROFITS, not for sharing passion of collection custom keycaps. I hope that K3KC will sell BBs replicate at 10$ -15$ for everyone who want to get custom keycaps but they are no many cash to buy. Because you choose the buyers ? maybe.
I have only 1 Reaper and i was sold for my friend with retail price and never buy and collection BBs again. I don't like a guy like as you.
Goodluck Bro ;)
@Moderators: sorry about my replies in this thread, i don't want to do that but ....
« Last Edit: Fri, 17 October 2014, 04:08:34 by pmh1410 »
Offline Michael
  • Formerly Bro Caps
« Reply #3168 on: Fri, 17 October 2014, 04:10:00 »
ftfy
Okie, no pbls sir.
Goodluck Bro ;)
That's some interesting excuses for being a thief. I see the 'quality' your friend produces, and it's absolute garbage. You get what you pay for. You don't see passion? Because you don't know passion. You are a window-licker who doesn't want to put forth the effort into the hobby, but wants all of the rewards right now. You don't have to agree with my price, instead, you can go look to other cap makers or just choose not to buy. But no, instead you steal others work and profit from it. You and your friend are both scum. So don't come here and try to make excuses for your disgusting behavior.
« Last Edit: Fri, 17 October 2014, 04:44:47 by Bro Caps »
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #3169 on: Fri, 17 October 2014, 04:51:10 »
I understand the anger about k3kc but can we please keep it in the the designed threads?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3170 on: Fri, 17 October 2014, 06:21:56 »
Take a look here. For someone who designs his own caps and works in small batches, $15-20 a cap is the basic cost price. If someone makes several new designs each year, that price increases drastically. So $35-50 per keycap is not ripping people off but actually a fairly reasonable price. It's a 100% increase at best.
Someone that is stealing somebody else's designs: $4
And only if they do not throw away caps with flaws in them. a.k.a. low quality control.
The only one making big profits is K3KC, charging $16 for a $4 cap.
For those who have troubles calculating the increase, that's 300%
I understand that $50 a cap is a lot of money and it feels like a bunch of rich American/European guys keeping the little Asian guy down. But it isn't.
He could design his own caps and with the same level of quality sell them at $30-40 a piece because of the lower wages.
But he would have to make a name for himself. And instead of building respect he just copies someone else's hard work.
And that is what people here, especially cap makers, are angry about.
« Last Edit: Fri, 17 October 2014, 06:27:46 by JaccoW »
|||My other keyboards :
x
« Reply #3171 on: Fri, 17 October 2014, 06:25:24 »
I'm not defending K3KC's actions or anything, but I don't understand this..
Unless K3KC is getting his mass produced [seriously doubt this] where does that $11-16 difference come from? Unless you're counting in the time it takes to design it.
« Last Edit: Fri, 17 October 2014, 07:39:24 by Photekq »
Offline Michael
  • Formerly Bro Caps
« Reply #3172 on: Fri, 17 October 2014, 06:33:49 »
In case you weren't aware, k3kc is selling them for 25-35 per cap, so with literally around the same prices for counterfeit caps with considerably less quality, how is pmh1410's argument about mine being expensive, valid?
« Reply #3173 on: Fri, 17 October 2014, 06:48:10 »
Take a look here.
I realize this is completely off topic but I'm not sure that thread is very valid as to what cap making really costs.  ::)
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #3174 on: Fri, 17 October 2014, 06:49:11 »
do we really think pacifist is the best source of info on the costs of making hand made artisan caps
Offline BunnyLake
  • X
« Reply #3175 on: Fri, 17 October 2014, 06:49:33 »
ray ninjad me
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #3176 on: Fri, 17 October 2014, 06:56:58 »
Does this **** need to be everywhere on this forum, now?
Can I get like an email notification when we're finally done talking about cheapskates, counterfeiters, and novelty keycaps, please?
If today had been a hippo, then you'd really have to worry about tomorrow.
« Reply #3177 on: Fri, 17 October 2014, 06:57:27 »
LOL +100
Offline pmh1410
« Reply #3178 on: Fri, 17 October 2014, 07:27:57 »
Cost of them around 5-7$/each not more ;). They all made by Resin plastic.
« Reply #3179 on: Fri, 17 October 2014, 07:32:11 »
Pepperidge Farm remembers when this thread was about Korean keyboards.
Feelin' my slim and simple style....and a Beretta. A wise man once told me, as long as I got my Beretta, I'm down for whateva.
Offline BlueBär
« Reply #3180 on: Fri, 17 October 2014, 07:34:05 »
What's a Korean keyboard?
« Reply #3181 on: Fri, 17 October 2014, 07:34:42 »
I literally just showed you the penultimate Korean keyboard. Please hold your tongue when asking such asinine questions in the future.
« Reply #3182 on: Fri, 17 October 2014, 07:35:56 »
79997-0
They come with this sticker.  :-*
Offline pmh1410
« Reply #3183 on: Fri, 17 October 2014, 07:51:03 »
Nice Eagle :thumb:
Offline HPE1000
  • Keycap Paparazzo
« Reply #3184 on: Fri, 17 October 2014, 08:14:48 »
ftfy
Okie, no pbls sir.
Goodluck Bro ;)
Hmm, well I shouldn't be responding but this is just too good....
Could you please tell me how much click clack sells his skulls for now? $40-60+. Is click clack making BIG PROFITS? Is click clack not interested in making people happy and sharing his designs?
Tell me that please...
And click clack is making the SAME design as he has from the start, bro caps is always coming up with cool and interesting designs. Click clack has only made a few designs over the course of his entire "career" but his prices still go up.
And now that that is aside, click clack is making $40-60+ each skull keycap but yet you don't have anything wrong with click clack, do you? (Or I think you do, since you are supporting a counterfeiter who is ripping off his work)
Don't get me wrong, this is not a jab at click clack.
ALSO, your friend is clearly making the fake brobots as a way of getting back at bro caps, right? So why would he put the prices high when his only intent seems to be to hurt bro caps? He isn't selling his click clack knockoffs for $10 is he? So tell me why the hell that is.
Also, if it is only 6-7 dollars to produce a keycap, your "friend" is making big profits as well, right? And that is big profits on stuff he didn't even design.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #3185 on: Fri, 17 October 2014, 08:20:05 »
Oh man, how could I forget the was the fake cap thread. Oh wait...
and since this is the Korean thread, if anyone sends me a 456gt I'll be sure to take some nice pictures :p
Offline Elocutive
« Reply #3186 on: Fri, 17 October 2014, 08:30:47 »
If I could buy a custom off someone, fantastic pictures will be taken!
LZCE- Black, red, ergo clears
Wanting Skeldon
« Reply #3187 on: Fri, 17 October 2014, 08:34:33 »
We really need to keep this on topic, everyone.  There are already quite a few threads dedicated to this issue, and we have already derailed quite a few other threads.  Let's please keep this topic to Korean Keyboards.
(last couple posts are on topic, but this still needs to be said)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3188 on: Fri, 17 October 2014, 08:41:49 »
nvm.
Moar KOREAN!!!
x
Offline byker
  • Literally Canada
« Reply #3189 on: Fri, 17 October 2014, 09:49:53 »
This is too good. Made me laugh at 8 AM :)  :))
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #3190 on: Fri, 17 October 2014, 10:34:47 »
I got boards.
« Reply #3191 on: Fri, 17 October 2014, 10:35:40 »
Wow those caps are pretty yellowed and that board looks weird. What's up with those square stems? I think you should send that this way so I can further inspect it.
Offline frosty
  • jukebox hero
« Reply #3192 on: Fri, 17 October 2014, 10:37:34 »
I'll like to inspect it too :(
Nice board margo!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3193 on: Fri, 17 October 2014, 10:38:38 »
nice caps, bout as yellowed as mine :p. What board did you get those from?
  • Dungeon Dweller
  • Get back to work!
« Reply #3194 on: Fri, 17 October 2014, 10:45:06 »
hehe I like the yellowed-ness, gives it character :)
Nice board margo!
thanks  :thumb:
Came from a Heu-292, the keyboard itself is rubbish, fun alps clones on it though, salmon coloured clones with a green coloured clone on the space bar.
I got boards.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3195 on: Fri, 17 October 2014, 10:48:34 »
x
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #3196 on: Fri, 17 October 2014, 11:02:29 »
woho nice caps margo :thumb: :cool:
« Reply #3197 on: Fri, 17 October 2014, 12:29:34 »
Offline HPE1000
  • Keycap Paparazzo
« Reply #3198 on: Fri, 17 October 2014, 12:30:24 »
Pardon my ignorance, what board is that?
I REALLY want a custom alps board like that with some linear green switches on it.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #3199 on: Fri, 17 October 2014, 12:31:44 »
