Author Topic: Post your Korean Keyboard ^_^  (Read 14099678 times)
0 Members and 10 Guests are viewing this topic.
Offline juahenza
  • DoSmallThingswithGreatLove
Re: Post your Korean Keyboard ^_^
« Reply #9000 on: Tue, 17 January 2017, 23:43:47 »
EM.7 by Hanshen, on Flickr
Nice two seated sofa
Sent from my LG-H961N using Tapatalk
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Jokrik
« Reply #9001 on: Tue, 17 January 2017, 23:53:27 »
Thinking about it, I can really buy a good sofa with that board haha
Offline alienman82
« Reply #9002 on: Wed, 18 January 2017, 00:03:23 »
removed.
« Last Edit: Thu, 01 March 2018, 13:21:43 by alienman82 »
Offline exitfire401
  • The Force is Re/\l
« Reply #9003 on: Wed, 18 January 2017, 00:10:54 »
the more i think about it the extra key on he bottom row is nice wish my VEA could have b on the right half but then again it would look strange split like it is.
cool board nice cable
Adjusting to hitting B on my VE.A is the only thing still tripping me up about this board. Adjusted to hitting Y with my right hand no problem. B is just still so weird to hit with my left hand. Minuscule complaint overall. I love everything else about this board.
Offline Rayoui
« Reply #9004 on: Wed, 18 January 2017, 08:09:05 »
I thought B with left hand and Y with right hand was standard. That's how I learned it anyways. Suppose it could go either way.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
« Reply #9005 on: Wed, 18 January 2017, 21:17:41 »
Just, twoooo brothers. Big brother should be mailing soon. Little brother needs a full matching set as well.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9006 on: Wed, 18 January 2017, 21:36:31 »
I believe that is the "correct" way. I switch back and forth when using a staggered layout.
Offline Jokrik
« Reply #9007 on: Wed, 18 January 2017, 22:05:16 »
woah, is that pink?
« Reply #9008 on: Wed, 18 January 2017, 22:26:05 »
woah, is that pink?
It's "red", the infamous LZ-GH "red". The one above it is titanium grey though ;)
Offline Heist
  • Warchief of the Horde
« Reply #9009 on: Thu, 19 January 2017, 08:25:10 »
That LZ GH  :eek:
Offline Phenix
« Reply #9010 on: Thu, 19 January 2017, 09:41:58 »
Whats this board?
handwired??
Winter is coming.
Offline joey
« Reply #9011 on: Thu, 19 January 2017, 09:46:57 »
Whats this board?
handwired??
No, it's em.7
Offline alienman82
« Reply #9012 on: Thu, 19 January 2017, 09:48:23 »
removed.
« Last Edit: Thu, 01 March 2018, 13:16:47 by alienman82 »
Offline E3E
« Reply #9013 on: Thu, 19 January 2017, 09:51:18 »
Whats this board?
handwired??
No, it's em.7
handwire your kustoms to save the PCB!  sell as new kit later!  GREAT IDEA
Oh god lol
Offline Phenix
« Reply #9014 on: Thu, 19 January 2017, 10:09:46 »
(captain obvious strikes again)
EM7 stands even there..
Winter is coming.
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #9015 on: Thu, 19 January 2017, 13:58:36 »
Whats this board?
handwired??
No, it's em.7
It would actually be pretty cool to see a handwired LZ-CP or TX1800 with alps.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #9016 on: Thu, 19 January 2017, 14:07:32 »
good luck with caps.. also would need a different plate for the stabs
« Reply #9017 on: Thu, 19 January 2017, 14:18:27 »
I thought about that, Alps stabs would be a no-go and the only usable caps would be something DCS or DSA. As for the larger keys, those enabler PCBs with MX stabilizers might work. Still too many compromises...
Offline E3E
« Reply #9018 on: Thu, 19 January 2017, 16:05:28 »
That's not true, there are many ways to create a cap set that would fit the 1800 layout. You'd just need to design the plate for it, get it lasergist'd, and you'd be good to go. For a simple route, you could use Tai Hao caps.
Most focus boards would have the caps you'd need, then you'd get an Omnikey in ANSI for the ANSI enter.
Some of the early Leeku MX 1800 PCBs were MX + Alps.
You could also use MX PCB stabs if you designed the plate for it and had the appropriate caps. I just used an Acer 6011 plate that I modified myself to have slots for MX stabs when I built my Leeku 3000 NCR with Alps.
The caps I used, the Tai Hao FAME TH-5539 Cherry-profile doubleshot caps, would almost entirely cover the 1800 layout except for a few minor things. I had to use OG Cherry doubleshots to get the ANSI layout for the G80, but yeah.
I think it'd be fun.
I just built up an MX1800 for someone too. I was thinking of how neat it'd be if it were Alps. The 1800 layout isn't really my thing, but it would still be cool.
« Last Edit: Thu, 19 January 2017, 16:17:16 by E3E »
Offline alienman82
« Reply #9019 on: Thu, 19 January 2017, 16:24:38 »
removed.
« Last Edit: Thu, 01 March 2018, 13:16:26 by alienman82 »
« Reply #9020 on: Thu, 19 January 2017, 16:32:19 »
^Very true, I was just talking in the context of using the stock plate. Alienman's alps plate he got cut for his VE.A  came out great but remember, we are trying to save the PCB.
Offline E3E
« Reply #9021 on: Thu, 19 January 2017, 18:05:55 »
just fill all the stems with epoxy and hand mill them.  Actually if you had a rig for that and an actual mill, I bet it wouldn't be that hard.  And you'd be sure to win a wingnut
Yep! That's exactly what I did for the Cherry caps I had to modify for my NCR. Not with epoxy, but close enough.
If you were speaking strictly about using the TX or LZ-CP, then I'm not sure about that. As far as I know, the TX series sources PCBs from Leeku, so is the PCB in the TX 1800 just an MX1800?
Looks like it to me. So just find an older version of the PCB with MXAlps, and you'd be on the right track. Leeku won't be making those again though.
« Last Edit: Thu, 19 January 2017, 18:08:32 by E3E »
Offline h1ggs
  • @switzcaps
« Reply #9022 on: Fri, 20 January 2017, 15:36:21 »
CPSQ by Leeku with vintage Cherry Double-shots  :-\
Offline cicada
  • Formerly iamacicada
« Reply #9023 on: Sun, 22 January 2017, 01:05:34 »
Finally I can post here :)
158226-0
« Reply #9024 on: Sun, 22 January 2017, 01:45:22 »
Offline SaySo
« Reply #9025 on: Sun, 22 January 2017, 03:08:41 »
« Last Edit: Tue, 03 July 2018, 12:55:01 by SaySo »
Offline iwantatrophy
« Reply #9026 on: Sun, 22 January 2017, 04:36:59 »
What keeb is that? Looks soo sexy
Offline nasby99
« Reply #9027 on: Sun, 22 January 2017, 04:50:01 »
It that  what you told me? ^_^
나의 B1-750 의 Tapatalk에서 보냄
What I have currently
356CL(Black,Gun-metal), 356L, 356.2, 356DGE,356N MK2, 356MINI v1(military,red) 356MINI v2(red) 360c(apple silver,hyper blue),Koala,Cheat..
G81-3000SAV, G81-3100SAV,G81-3004SAT,G81-3000SAT,G81-3000SPBUS,G80-3000HAV,G80-2100HDU...
What I want to get now
Nothing atm
Offline hanoipho
« Reply #9028 on: Sun, 22 January 2017, 05:20:40 »
Offline cicada
« Reply #9029 on: Sun, 22 January 2017, 07:34:42 »
Thanks! It's a 356mini.
Offline jerue
  • (Whenever that happens :P)
« Reply #9030 on: Sun, 22 January 2017, 09:11:38 »
the more I look at these the more I want one...very nice  :thumb:
Offline alienman82
« Reply #9031 on: Sun, 22 January 2017, 09:36:04 »
removed.
« Last Edit: Thu, 01 March 2018, 13:14:49 by alienman82 »
Offline pr0ximity
« Reply #9032 on: Sun, 22 January 2017, 09:46:11 »
Offline ctzn_voyager
« Reply #9033 on: Sun, 22 January 2017, 15:42:22 »
Duck's are Korean, right?
Offline sundin
« Reply #9034 on: Sun, 22 January 2017, 15:52:48 »
Offline alienman82
« Reply #9035 on: Sun, 22 January 2017, 15:52:49 »
removed.
« Last Edit: Thu, 01 March 2018, 13:14:38 by alienman82 »
Offline nasby99
« Reply #9036 on: Sun, 22 January 2017, 15:55:12 »
Quak  quak  quak~!!(korea duck crying)
Nothing atm
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #9037 on: Sun, 22 January 2017, 16:01:05 »
Offline Khers
  • Schrödinger's box
« Reply #9038 on: Mon, 23 January 2017, 00:39:54 »
« Last Edit: Tue, 03 July 2018, 08:59:35 by Khers »
Offline cicada
« Reply #9039 on: Mon, 23 January 2017, 04:48:48 »
Thanks! It is indeed a board that I've wanted for such a long time. I remember asking you guys a bunch of silly questions for tips on how to obtain one.
Shoot, now I might have to go ask pr0ximity how to reprogram this thing. The default layout works well for me though.
Offline pr0ximity
« Reply #9040 on: Mon, 23 January 2017, 05:20:48 »
Been meaning to post info on that, I've got the GUI for it and permission to rehost it. Will put a thread together soon. If you're really interested you'll need an AVR ISP.
Offline cicada
« Reply #9041 on: Mon, 23 January 2017, 10:46:21 »
Oh yes that'd be really great! I'll be looking forward to it  :thumb:
Offline henz
  • What?
« Reply #9042 on: Mon, 23 January 2017, 14:16:43 »
Finnished my Orion today, its looking fine if i may say so myself :)
« Reply #9043 on: Mon, 23 January 2017, 14:32:25 »
nice...
« Reply #9044 on: Mon, 23 January 2017, 17:05:39 »
What gamer sets are those?
« Reply #9045 on: Mon, 23 January 2017, 17:19:56 »
Should be Chill Blue from the "reapers n gamers" sale...
I actually won a Chill Blue set from the raffle but was refunded because they ran out or something T_T
« Reply #9046 on: Mon, 23 January 2017, 17:24:23 »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9047 on: Mon, 23 January 2017, 17:27:52 »
uh huh, suuure they did
JK, I believe you
Offline henz
  • What?
« Reply #9048 on: Tue, 24 January 2017, 00:22:24 »
Sorry to hear man :(
Offline chilldude_22
  • Official streetman
« Reply #9049 on: Fri, 27 January 2017, 08:25:05 »
I have a set I don't use much. It would look great on your LZ
